I am giving the Sedan a birthday (before lots of Summer - cruising to the beach) with new brakes and I assume new discs (I know the back ones need replacing)
Parts sourcing:
Are Bendix ok for pads?
Where do I get the discs? - I have only ever fitted secondhand ones on the past.
300D brakes
- GrampiansMerc
- M-100
300D brakes
1980 w123 300D Silver sedan
1980 w123 300TD "Anna" - sold
1979 300D - sold, gone to be restored
2006 Musso - Korean Mercedes, 5 cylinder diesel - Blown head gasket, buggered motor, grrrrrrr (I will stick with German Mercs)
I'm just a simple man trying to make my way in the universe
- 300 SLR
Re: 300D brakes
I use Bendix pads - They are OK. Make sure you order the right thickness for the fronts as there are two sizes. Bendix Discs / Rotors as well
- Ponton
- Model you own: w108
Re: 300D brakes
I've previously bought rotors from run auto. Shipping from overseas was cost prohibitive at the time, but this was a year or two ago. My 300d doesn't need great pads as there's not much to show down, but if you're after low dust, maybe try ceramic type pads
1971 W108 280SE 3.5
1982 R107 500SL
1977 W123 300d
2023 X254 GLC300
1982 R107 500SL
1977 W123 300d
2023 X254 GLC300
- GrampiansMerc
- M-100
Re: 300D brakes
Hey Tim
Can you explain the two different thicknesses in front pads? different years or models or wagons vs sedans
Re: 300D brakes
The front pads up to 10/1979 were 15mm thick, from 11/1979 they were 17.5mm thick.GrampiansMerc wrote: ↑Mon 04 Dec, 2023 10:34 am Can you explain the two different thicknesses in front pads? different years or models or wagons vs sedans
- GrampiansMerc
- M-100
Re: 300D brakes
Thanks John
Good information as always on both pads and coil packers.
- GrampiansMerc
- M-100
Re: 300D brakes
Went to Bursons, Bendix pads $140 for the rear sets.
It seems a little dear, but maybe thats my fault for going to Bursons...
I didnt price front pads...thats next, but may not go back to Bursons.
