Interesting turbo set up on this one. (listing nothing to do with me)
https://www.lloydsonline.com.au/LotDeta ... =1&pgs=100
300D Turbo on Lloyds
- GrampiansMerc
- M-100
- Model you own: w123
Re: 300D Turbo on Lloyds
Wow low kms...26570
1980 w123 300D Silver sedan
1980 w123 300TD "Anna" - sold
1979 300D - sold, gone to be restored
2006 Musso - Korean Mercedes, 5 cylinder diesel - Blown head gasket, buggered motor, grrrrrrr (I will stick with German Mercs)
I'm just a simple man trying to make my way in the universe
Indicated but by the images it looks pretty well could be so.
Is this listing current? text is insisting on social distancing for health reasons - ancient history now. (unless vendors age extremely aged?)
Seems a low price currently - shade over $10K.
I'd put a bid in but if I bought it home, I'd be shot at dawn.
Trying to access Lloyds.com.au - bad gateway
Current
S212 - E350 Wagon
W213 - E220d
S212 - E350 Wagon
W213 - E220d
- 300 SLR
That looks like it is using the 85 Californian version of the turbo air cleaner - relocated to accommodate some anti pollution gear (trap box oxidiser ?). I have considered getting one as the standard OM617A likes to foul the air cleaner against the front outlet on the master cylinder ....
- 300TDT
- M-100
Auction now closed but I cannot access winning bid.
Looks like winner was C512293? Anyone?
That aircleaner set-up looks similar to one that I owned previously.
With an oil bath aircleaner.
Turbo conversion (OM617.952) done by Herscheid Restorations in Salt Ash NSW - a 'frankenstein'.
@tsharkey, interesting about the fouling of the standard aircleaner on the master cylinder. I'd never heard that before.
300TD : WDB123.193 '83 model, anthracite grey (172), cream cloth (055)
Interesting. One of my favourite W123 mods is to fit the bigger W126 booster which bolts straight in and just moved the master forward by around 5cm. It give way better brake pedal feel under heard braking. Might not be possible with the OM617A in RHD form.
- 300 SLR
Thats right John, I tried fitting the larger vacuum booster, and the brake pipes on the LHS of the master cylinder foul on the air cleaner. Still fitted the vented discs and wider calipers tho.
