Hi Any Ideas
98 w210 e240 wagon all brake lights on and front right parker. and key removed
step on pedal .warning lights come on dash . clicking in passenger footwell .
start car switch off ignition egine still runs . step on brake ,engine stops ,,,,brake lights still on ..
remove fuses from drivers fuse box ..lights still on .. remove relays still on rear wiper not working also
remove both rear tail light assemblies .. center brake light still on . remove brake switch under dash
test with mmeter open circuit closed when plunger depressed disconnect rear black module ...........still on
checked all fuses in all 4 locations ..k4 area drivers engine side . drivers inside box and under back seat
and yep test fuse 2 (did all) for brakelight and see if getting power at holder ..no thing
and all ground connections are tight and good i think 8-9 hours into this
oh and add trailer plug and electric brakes into the mix
have booked it in ,but trying everything first
brake lights
- B Class
- Region: Victoria
- Bartman4800
- SLS AMG
Re: brake lights
I have a W212 which is all LED, so not entirely familiar with W210.
But: You would not have installed a dual brake/tail light globe wrongly in its socket? That can give some weird behaviour.
Other than that: could it be there is some biodegradable wiring in the mix?
2012 W212 E250CDI
2012 W212 E250CDI
- B Class
- Region: Victoria
Re: brake lights
Hi Bart
thanks for tghe reply
yes can be an issue but disconnecting and removing both rear light assenblies should eliminate that possibility
removed the sockets .middle brake light still on
remove entire assemblies .. still center brake on .... doh
dropping the car and my wallet to merc guy with star thingy tomorrow
getting new car for wife
and probably sell the w210 . if it can be fixed
- B Class
- Region: Victoria
Re: brake lights
car back yesterday
they thought brake switch first .then headlight switch/fusebox
and ended up being in rear right brake light .
fixed
fixed
- Region: Victoria
Re: brake lights
W210
Tail light assemblies - all the bulbs are subject to the screw in holders corroding.
Every now and then need to remove the bulb assemblies clean them up, make sure tag tensions are Ok and re install.
Current
S212 - E350 Wagon
W213 - E220d
S212 - E350 Wagon
W213 - E220d
