flasher unit.
- 450 SEL 6.9
flasher unit.
As the subject states my flasher unit died and a replacement flasher unit works too fast. Anyone, John Green, know of a replacement?
1978 W123 300D Maple Yellow
1983 W123 280TE Champagne
1975 W116 450SEL Silver blue
- Bartman4800
- SLS AMG
Re: flasher unit.
If the replacement flasher unit works too fast, it might be because of the incorrect wattage of your bulbs. Have a check.
2012 W212 E250CDI
2012 W212 E250CDI
- Chai
- OZBENZ moderator
- Model you own: w107
Re: flasher unit.
Hi Pete,
Is the replacement flasher for your 1975 W116 the original BOSCH relay as described in my post in viewtopic.php?t=27181?
Bart is right about the relay expecting the indicator bulb wattage (both the front and back) to be within a particular range for the flash rate to be right. One blown bulb will speed up the click rate.
Chai
1974 450SLC
1974 450SLC
Re: flasher unit.
what Chai saidChai wrote: ↑Wed 01 Feb, 2023 5:22 pm Hi Pete,Is the replacement flasher for your 1975 W116 the original BOSCH relay as described in my post in viewtopic.php?t=27181?
- 450 SEL 6.9
Re: flasher unit.
Thanks everyone, the flasher is incorrect. I will purchase the one tomorrow.
