W124 M103 Fluctuating Idle Woes
- Pagoda
Hi all,
I'm trying to diagnose/fix a 'bouncing' or fluctuating warm idle issue on my '89 M103 260E. When started when hot (above or at 80c) the idle speed will bounce from 450/500RPM to 1000RPM, back and forth. Reading pin 3 of the X11 diagnoistic port (with pin 2 used as a ground), I obtained a reading of 50.6% - O2 sensor. Checking the voltage of the O2 sensor (which, as I understand, should fluctuate between 0.1 and 0.8v), I determined it was dead (readings were between 0 and 0.1v). However, after changing the O2 sensor today, I am still getting the same 50.6% reasding from the X11 port on my multimeter. That reading will remain there for a while before the figure creeps up to 82% and oscilates between 81.9% and 82.1%. Any ideas? I'm exhausting most online forums and searching at this point.
Thanks in advance
Harry
Thanks in advance
Harry
W123 300D – The White Maiden (Regretfully Sold)
W115 220 – The White Maiden II
W124 260E - New daily
Located: Melbourne, Victoria.
- Bartman4800
- SLS AMG
Re: W124 M103 Fluctuating Idle Woes
It sounds like you have a vacuum leak. And most likely, around the injectors.
Here is Kent explaining what to do about it: https://www.youtube.com/watch?v=pOZRHt-GkHY
2012 W212 E250CDI
2012 W212 E250CDI
- Pagoda
Thanks for the reply Bart. I'll look into the injector situation. What is the best means for testing for vacuum leaks throughout the engine bay?Bartman4800 wrote: ↑Thu 23 Jun, 2022 2:13 pm It sounds like you have a vacuum leak. And most likely, around the injectors.
My money would be on the air flow meter sensor. The small black box on the side of the air flow meter. They get dead sections in them over time. Mark its position carefully and then move it around a little to see what happans.
- Bartman4800
- SLS AMG
Spray a bit of brake cleaner around the injectors, if the revs rise you have a leak...hazzac181 wrote: ↑Fri 24 Jun, 2022 9:36 pmThanks for the reply Bart. I'll look into the injector situation. What is the best means for testing for vacuum leaks throughout the engine bay?Bartman4800 wrote: ↑Thu 23 Jun, 2022 2:13 pm It sounds like you have a vacuum leak. And most likely, around the injectors.
2012 W212 E250CDI
2012 W212 E250CDI
- Pagoda
Reporting back after a little investigation. I built my own smoke tester and found, low and behold, the seals on injectors 1, 2, 3, 4 and 5 are bad. Added to the 'to-do' list. Are parts available from MB or is my best bet online?
I also saw quite a lot of smoke coming from this plug, underneath the air flow meter housing. See the attached images. Is anyone able to identify what this is, and what it does? Either my googling skills are poor, or I've completely missed what this little guy is.
Once again, I appreciate all help
- Pagoda
Hmm, images not uploading as anticipated. See links below:hazzac181 wrote: ↑Tue 28 Jun, 2022 12:32 am Reporting back after a little investigation. I built my own smoke tester and found, low and behold, the seals on injectors 1, 2, 3, 4 and 5 are bad. Added to the 'to-do' list. Are parts available from MB or is my best bet online?
https://imgur.com/dlV7qR8
https://imgur.com/mTwVfqH
- Pagoda
Upon re-reading your post, it appears the black box in question is indeed the air flow meter sensor. Would I be correct? If so, 100% success rate from both of you so far!John Green wrote: ↑Sun 26 Jun, 2022 9:17 amMy money would be on the air flow meter sensor. The small black box on the side of the air flow meter. They get dead sections in them over time. Mark its position carefully and then move it around a little to see what happans.
Nearly all vacuum leaks are a constant. So for example if you have unmetered air getting in, it is always getting in. So not the most likely cause of a fluctuating idle.
The plug in red is not a plug. It is the switch on the throttle body. It essentially has three positions. Shut, full open and in between these points. The smoke will be caused by wear in the throttle body shaft or the alloy housing, but once again this is a constant.
- Pagoda
Understood John, thank youJohn Green wrote: ↑Tue 28 Jun, 2022 12:40 pmNearly all vacuum leaks are a constant. So for example if you have unmetered air getting in, it is always getting in. So not the most likely cause of a fluctuating idle.
