Looking for some help and advice please.
While my mighty 240D drives quite straight, the steering has the dreaded 1”+ of free-play in the straight ahead position, and it will not adjust out. I was wondering what options there are. Can these steering boxes be successfully reconditioned, the local shop (central Qld) said there can be problems due to how they wear, and would have to send it away to get done. Should I look for a good second hand unit, but do they exist these days? Will boxes from any other models such as the W126 go into the W123 without any modifications?
Thanks in advance.
Steering Box Help
- S Class
- Region: Queensland
Steering Box Help
1984 300D - Gold, Gold, Gold
1984 280CE - Silver Blue
1981 240D - White
1970 Valiant VG VIP - White - Distant relative
1981 240D - White
- 300 SLR
Re: Steering Box Help
I have seen you tube videos of them being "reconditioned" - ie: New seals but not fixing play etc.
I have read on the US forums that the W126 box fits and offers the S Class feature of auto slack adjusting .....
See here
https://www.benzworld.org/threads/w126- ... st-5010081
Note it is a LHD discussion. Also W126 Series I. Also Pitman Arm will need to be retained.
See here
- Maybach
- Model you own: w202
I'd check the bearings,bushes&oil seals.
- S Class
Thank you. I read through the post and it seems that the W126 steering box from Series-1 could interchange, the “auto compensation” sounds interesting. Anyway will try and track one down and check out the compatibility, there are a few more W126s being parted out up this way, not so many W123s unfortunately, and all my spares are pretty tired. Just trying to work out a way to go at the moment. Ron B does have a YouTube series on a W114 box rebuild, and it looks a bit involved.....
https://youtu.be/ZL4kZieJZUU
Everything has been checked out and all couplings, tie rods etc are good. Hoping it wasn't to be a box problem.....
Thanks once again.
Thanks once again.
1981 240D - White
1981 240D - White
I presume that it is being correctly adjusted? I ask as I have see a few that have been adjusted by mechanics used to working on local cars get it back to front. On a MB the adjuster needs to the wound out. On most other recirculating ball steering boxes it is wound in.
- S Class
Hello John,
Thanks, yes turning CCW, the adjuster is quite a ways out and turning any further is causing binding unfortunately.
What do you usually recommend in regards to worn steering boxes? Does the W126 possibly interchange?
Thanks again.
Thanks again.
1981 240D - White
1981 240D - White
