Diesel help
- S Class
- Model you own: w114
- Region: South Australia
Diesel help
So with many thanks to CraigB , my 240d is water proof
however i have long going issues with the om616 engine.
the transmission is rebuilt
I've had the valves adjusted , new glow plugs put in , all filters changed over , diesel purge.
the lack of power is a real worry , on day to day city commute , its not a problem as the roads are flat and the speed is 60-70kmh
but on weekend , driving to a property, up the freeway , it is dangerous , cant maintain speed when climbing, even drop down a gear makes no difference
what else do i need to investigate ?
zf friedrichshafen
- Bartman4800
- SLS AMG
Re: Diesel help
Have you checked that your prime pump is in good order? I know about Japanese versions, that have a gauze filter there.
It sounds like you have a fuel issue. If all fails, run the engine from a jerry can in the engine compartment.
2012 W212 E250CDI
2012 W212 E250CDI
- Dernburg Wagon
- Region: New South Wales
Re: Diesel help
Did you change the air filter? These models air filters get glogged with exhaust soot if you have a slight leak especially around the exhaust manifold to engine pipe flange gasket. Disconnect the filter hose from the intake manifold and go for a drive.
Decca
Decca
- S Class
Re: Diesel help
Thanks for the advice..
it wont even start now .
Glow plugs get warm ,
I've checked there's fuel coming ( the return lines have diesel in them )
It tries to turn over , and if i hold the starter long enough , can even get oil pressure up, no luck... This also drains the battery
even tried removing the oil cap to try and start it , of course the oil vapour comes out
any where else to check ?
zf friedrichshafen
- 300 SLR
Re: Diesel help
I bet you have an air leak. Replace all crush washers (incl on top of the fuel filter). The banjo bolts all have them. Not sure what IP you have but the four delivery valves probably have them as well.
Crack open the 4 injector lines at the injectors and see if fuel it coming out of those when cranking (disable glowplug). I have been known to pull them out so the starter can spin more freely to pump the fuel through the system.
Once the lines are wet at the injector,refit and enjoy.
- S Class
Re: Diesel help
interestingly
i looked inside the injection pump , and it is bone dry.
I wonder if thats causing the starting issues ?
zf friedrichshafen
- 450 SEL 6.9
Re: Diesel help
look at the fuel filter near the tank and the line from tank to filter as it seems like the blockage is in that section.
1978 W123 300D Maple Yellow
1983 W123 280TE Champagne
1975 W116 450SEL Silver blue
- Bartman4800
- SLS AMG
Re: Diesel help
I think Sharkey is more on the money. An air leak will cause a bone dry pump.
Or were you referring to the part lubricated with engine oil? If that is dry, the pump will wear out really quickly...
2012 W212 E250CDI
2012 W212 E250CDI
Re: Diesel help
Agree about the air leak, but would also double suggest that you not only drain the tank and check the filter in the base, but that you remove the fuel tank sender (under plastic bung in boot floor) and inspect the insides of the tank. If the filter and base of tank have a coating of black gunge, you have diesel algae.Bartman4800 wrote: ↑Tue 26 Apr, 2022 10:08 am I think Sharkey is more on the money. An air leak will cause a bone dry pump.
- S Class
Re: Diesel help
Wow been a few months
time for an update
replaced the alternator and starter motor.
now it starts first time after glow plugs get warm
diesel smoke , this is ongoing ,at idle , there is bluish smoke
then last month, the vacuum pump diaphram went ( brakes were really hard to press )
managed to replace that and brakes are good
this old diesel sure has its quirks
time for an update
zf friedrichshafen
