Auto Trans Pan
- Dernburg Wagon
Auto Trans Pan
Searching for a "pan" for the auto transmission . To suit the later version W114 280 with Carby - has securing screws recessed into pan, as opposed to exposed screw heads
Re: Auto Trans Pan
You can fit any of the four bolts pans, so long as you then use the filter that suits that pan. I am presuming yours is warped from over tightening and leaks?
- Dernburg Wagon
Re: Auto Trans Pan
Many thanks for that, John. I was not aware of the interchangeability. Good to know.
