Hi all,
I have a '72 220. I've not read raving reviews on the Zenith/Stromberg(?) carburettor fitted to the M115. My carburettor is running rich/flooding, and is fouling plugs and causing the engine to run terribly. It is undrivable. My questions are as follows: are there rebuild kits available for these? I have tried one prior and had to put the original gaskets back in for a secondary diaphragm looking item as the replacements did not fit. To that end, is there a mechanic in the greater Melbourne (or Gippsland) region that is familiar with these engines/carbs? I am out of my depth here.
I have also considered replacing the carb. Has anyone done this? Is there a known swap? Ultimately, I am just looking for the car to run smoothly, I am not too fussed RE originality (although a rebuild of the original would be preferable. It is worth noting that the auto choke has been replaced with a manual unit fitted to the front of the carb.
If anyone has any experience/pointers, that would be greatly appreciated.
Harry
W115 220 Carb
- Pagoda
W115 220 Carb
W123 300D – The White Maiden (Regretfully Sold)
W115 220 – The White Maiden II
W124 260E - New daily
Located: Melbourne, Victoria.
- T-Modell
- die Nützlichkeit Meister
- Model you own: w107
- Region: EU- Western
Re: W115 220 Carb
Hi Harry,
I cannot help you with the carbs as I have zero experience in it. However, there's a great W114/115 wiki in Germany ... but in German. Maybe you can either read it or translate the parts about the "Vergaser" (carb), Zenith, Stromberg etc.
https://www.strichacht-forum.de/knowhow ... enzinmotor
There's quite a few articles about overhaul, fault finding, etc.
- Bartman4800
- SLS AMG
Re: W115 220 Carb
Redline is selling weber kits for just this:
http://www.redlineweber.com/carb-kits/a ... edes-benz/ Line 2
Regards, Bart
Regards, Bart
2012 W212 E250CDI
2012 W212 E250CDI
