swapping seats
- 450 SEL 6.9
swapping seats
A simple question fellas but is the answer as simple? The drivers seat on my '75 W116 450 SEL is a bit squeaky so I thought I might swap it for the passenger seat as it hasn't been used much. Are the seats interchangeable? I will try to fix the squeak while it's out as well.
1978 W123 300D Maple Yellow
1983 W123 280TE Champagne
1975 W116 450SEL Silver blue
Re: swapping seats
Yes, and No....... The spring base the padding and the leather cover for the base are the same, but nearing everything else is differant. It would be a massive job to change left to right. Just as an example the drivers seat is height adjustable. The passengers seat has the arm rest hanging off it, the list goes on.
- 450 SEL 6.9
Re: swapping seats
thanks for that John but on my car there are no front seat armrests. However the seat height adjustment kills that idea. Time to hunt the squeak.
- Chai
- OZBENZ moderator
- Model you own: w107
Re: swapping seats
If the squeak is in the seat base, then it's a case of
You don't have to completely remove the seat padding like shown in this photo to lube away the squeaks.
This photo was when I replaced the crumbled seat padding.
- removing the seat from the car and upending it on a platform/table
- opening up the metal clips that tie the seat material to the rear of the wire base with pliers
- Popping out the material from the seat front
- Squirt some spray lube everywhere the base springs meet up with the seat base
Chai
1974 450SLC
1974 450SLC
- 450 SEL 6.9
Re: swapping seats
Thanks for that info Chai. I'll give it a go.
- Chai
- OZBENZ moderator
Re: swapping seats
An alternative to spraying lithium grease is to spray lanolin ('Lanotec' brand) - oil from a sheep may help feed cow hide.
Chai
1974 450SLC
1974 450SLC
Re: swapping seats
All good comments, but if you have both seats out of the car, I don't see it as a massive job to swap the bases. The height adjustment is in the track mechanism, 6 screws holding it to the base - 2 screws on each side for the back...... no electrics .... maybe i have forgotten something.
