M110 fuel pump oil leak
- Nabstud
- 500 K
- Model you own: w116
- Region: Western Australia
I had what I though was a weep from my fuel pump, oil looked to be leaking from the black spacer/o-ring. I replaced the fuel pump but the oil leak still occurred. Took me a few goes but I finally pin pointed the leak to be coming from the fuel pump itself. There is a small manufactured hole at the bottom behind the pump part of the casting and that is where it is leaking from. Note it is oil leaking, not fuel.
Is that hole some sort of relief valve? Is there a trick to installing the fuel pump?
1975 W116 280S
- Nabstud
- 500 K
Re: M110 fuel pump oil leak
Here's a pic of the leak, you can see the oil drip on the fuel pump.
1975 W116 280S
It is an atmospheric vent so the diaphragm can do it's job. That looks like a cheap aftermarket pump, they are very prone to leaking. I will only use Pierburg pumps, the number is 7.02242.22.0
- Nabstud
- 500 K
Bugger. This is a new pump that came with other spares when I bought the car. Only been on for maybe 200km. Is this an ok brand?
1975 W116 280S
Looks like a Viaco pump which is part of the Vierol group of companies. No, sorry they are crap.
- Nabstud
- 500 K
- Nabstud
- 500 K
Where do I get a pierberg fuel pump? eBay aus says out of stock, eBay us says part doesn’t fit my car?
1975 W116 280S
- Bartman4800
- SLS AMG
Ruddies in Berlin has everything concerning carbs and pumps
https://www.ruddies-berlin.de/index2.html
2012 W212 E250CDI
2012 W212 E250CDI
- Nabstud
- 500 K
Cheers Bart, can seem to translate it on my phone, will try on the laptop later
1975 W116 280S
- Bartman4800
- SLS AMG
In the main menu, there is an "English" button.
Good luck and if you cannot find it I can help.
2012 W212 E250CDI
2012 W212 E250CDI
The english button doesn't work for me either when on computer - I think they set the site up with the intention but haven't quite got that far. When you hover the mouse over it there is no link... only when over the german button.
- Bartman4800
- SLS AMG
I think that website got built in the early 90 ties.
The guy still uses a fax for communication. To say he is "old school" is an understatement
If you send Thomas an email with exactly what you need, he can ask Ruddies in his own berlin dialekt.
Regards, Bart
Regards, Bart
2012 W212 E250CDI
2012 W212 E250CDI
