Hello all, I have 280SEL 1980 and need to replace leaking windscreen (front and rear) seals. Has anyone had any experience with this, be it with the larger companies or smaller specialist ones, specifically in Victoria ? Quality, price, any advice appreciated
Geelong Based here
Cheers in advance
Mark
Windscreen Rubber/Seal replavement
- Dernburg Wagon
- Model you own: w116
- Region: Victoria
Re: Windscreen Rubber/Seal replavement
I can't recommend locals for you, but try and find someone who knows your car - I had O'briens do significant damage to one of my cars, and of course they have lots of different people working for them, so best if you get a recommendation of a particular person. I can help for Adelaide.
Main thing to think about is seal quality - many say genuine is the only way to go. I've only used genuine so I can't vouch if other ones are bad or good. I don't know who the oem manufacturer is for the genuine ones.
- Dernburg Wagon
- Region: Victoria
Hi Craig, appreciate the advice. Do you have a rough cost from memory ?
Mark
Mark
For the seal? It was something like 120 cheapest and 150 genuine, but that wasn't a dealer and was from US. Its a guess - late and been away.... but a bit of a guide - need to check anyway.
- ngruzevs
- M-100
- Model you own: w126
I've recently done this, ordered both front and rears from the US and then got Roys Windscreens to install (I'm in Vic).
Current Garage
1971 Jensen Interceptor: Jeremy (Turns petrol into noise)
1977 Triumph Stag (manual): Scarlett
1979 W116 450SE: Claudia
2005 C209 CLK320: Michelle
2007 Lexus LS460: Larry
2018 Hyundai i30N (manual): Penelope
- AMG
- OZBENZ Admin
- Region: New South Wales
Are you happy with the result?
- ngruzevs
- M-100
Very happy. I've been burnt using non genuine rubber, so was happy to spend the extra. My attitude is that I won't remember how much it cost assuming job is perfect, but if not perfect I would always kick myself that I should have paid more for original MB parts.
Current Garage
