Vacuum???
Michel
Vacuum???
Post by Michel »
Doing some maintenance on my 6.9 this week (plugs, belts, etc...) uncovered a cracked vacuum ‘something’ see pic below.
I know it has something to do with the heater valve.
Can someone enlighten me as to where I can get my hands on one of those ?
Are they available new?
Michel (in Sydney)
W116: 1978 450SEL 6.9 - 690SEL # 3312
R107: 1985 500SL AMG - LHD
C208: 2000 CLK430
W140 1990 400SEL
R230 2003 SL350
Many other non-MB cars
Re: Vacuum???
Post by CraigB »
I'm not sure Michel, but just make the comment that it looks similar to other common 'vacuum elements'. If you pull it off and find a part number, you might find it is something common. I have started storing and cataloguing my parts under part numbers. When doing these I noticed some can have 2 part numbers, one on the element body and another on the arm. Not sure if you can mix and match but some look identical in the plastic body that is cracked on yours but have a different length arm on them. But hopefully someone knows more about your system and parts availability
Re: Vacuum???
Post by AMG »
Michel wrote: Sun 29 Sep, 2019 7:07 am Doing some maintenance on my 6.9 this week (plugs, belts, etc...) uncovered a cracked vacuum ‘something’ see pic below.
Michel,
This may help?
Chai
Re: Vacuum???
Post by Chai »
When the rubber bellow inside the vacuum element for the heater tap cracked, I replaced it with the item shown in this picture.
Chai
1974 450SLC
Re: Vacuum???
Post by AMG »
Chai wrote: Sun 06 Oct, 2019 2:37 pm When the rubber bellow inside the vacuum element for the heater tap cracked, I replaced it with the item shown in this picture.
That pic is the Same part on w201.
p/n A0148000052
:thumbup:
Michel
Re: Vacuum???
Post by Michel »
Thank you gentlemen for your help.
I found this on eBay USA
https://www.ebay.com.au/itm/Mercedes-w1 ... Sw899bke5O
Michel (in Sydney)
C208: 2000 CLK430
W140 1990 400SEL
R230 2003 SL350
