Rear axle/wheel inner&outer oilseals dimensions/MB part numbers&brand.
newMercowner69
Post by newMercowner69 » Tue 06 Aug, 2019 4:05 pm
Did MB engineers (or ZF) ? specify inner&outer oilseals in W202 series models for both the axle&wheels?,
Is ther an inner &outer seals for both the axle&hubs (wheels)?,
What's both the dimensions&O.E.M. supplier to MB&finally&lastly,
What's the MB part numbers?,
"Wagner wagon" has a whine in his arse (typical Kraut!!!!! :),
His dr/surgeon advised/diagnosed rear wheel bearings as being the cause/culprit,
Should i also change/replace the seals at the same time?,
Love&peace,
Regards&thanks,
"Wagner" &his fuerher Adro.
Re: Rear axle/wheel inner&outer oilseals dimensions/MB part numbers&brand.
Post by John Green » Thu 08 Aug, 2019 1:42 pm
The bearing is a sealed bearing, so no need for additional seals. And I would be pointing the finger at noisy diff carrier bearings, that is the most common cause for a noise like this.
newMercowner69
Post by newMercowner69 » Fri 09 Aug, 2019 11:35 am
I ordered , acquired, obtained &purchased, GENUINE O. E. M. bearing supplier to MB,
FAG 547103BA (original number was 547103E) , BA is new updated number,
Cost me $140 pair from my local CBC,
MOST bearing companies
Either can only order, procure&supply either PFI Chinese, jap (Koyo/Nsk),
Not even available in SNR here in Australia.
newMercowner69
Post by newMercowner69 » Fri 09 Aug, 2019 11:37 am
John,
Do you have the MB part numbers for the CWP bearings,
Or aftermarket bearing part numbers
I. E. FAG/TIMKEN?,
As my catalogs only go 🏃🚗💨up to 1990 as far as MB's concerned for differential bearing listings.
