soft close doors vacuum pump replacement or repair.
- pina4greg
- E Class
- Model you own: w140
- Region: Western Australia
Pulled out the vac pump from the boot and found that one of the lines had broken off the nipple. when taking off the other lines being so old, a small piece of each nipple has stuck inside the clips. can the nipples be replaced on these or do i need to source a whole replacement???
1992 W140 300se
- Bartman4800
- SLS AMG
- Model you own: w111
Re: soft close doors vacuum pump replacement or repair.
Ouch, that looks like a 1 piece injection moulded part.
Unless the connectors are screwed in, you will have to buy a new one.
You can always try to glue it with 2-pack araldite....
2012 W212 E250CDI
2012 W212 E250CDI
That's disappointing to have that sort of structure where they should have known when they made it, it would have a restricted life. Just thinking out loud, and I'm not an engineer, but my thoughts went to if you could get metal tube that would slip down inside the outlet or you could maybe ream a little bit out. You don't want to make it too much bigger and weaken it. Then with glue you could slide the broken outlet back over it. Basically sleeving all those outlets. Its the same method really as they did when they made stupid plastic tanks on radiators and the top outlet broke and many motors destroyed. Replacement radiators then had a metal sleeve inside the outlet to strengthen it.
I think it will have to slightly restrict the diameter but I don't think it would matter that much. I'm trying to think where i would go for tube. A brake place with different diameter brake and fuel lines? I'm picturing some brass tube i have seen too but can't remember where I have seen it. Carby place? fuel line?
- Finnie
- Model you own: w107
RS components have pneumatics and accessories.
There was a screw-in pneumatic mount that on the other end had push-in fitting.
If I remember correctly they were both positive and negative pressure type.
3 steps: Tap, teflon tape, smile
'80 450SLC 3-continental
- pina4greg
- E Class
thanks guys, will give those ideas a thought.....just need to have the hoses sealed into the nipples....have mentioned this on the benzworld forum so will see what they come up with....parts a lot more accessable in the uSA.
1992 W140 300se
Those pumps have been a short coming since the day the W140 was released.
Plenty of articles on the internet about the pumps.
The pump in my car broke down within 18 months from new.
Current
S212 - E350 Wagon
W213 - E220d
S212 - E350 Wagon
W213 - E220d
- pina4greg
- E Class
at least the doors still work other than closing a bit harder.... looking at a remanufactured one in the usa for about $450....or may wait a while...
thanks for everyones imput..
1992 W140 300se
- pina4greg
- E Class
Still looking for the Vaccum Soft close pump.....my part no. is 140 800 0848......i see there are some 140 800 0948 for sale and look similar for s class.
are these actually interchangeable??????
please..
GReg.
please..
GReg.
1992 W140 300se
- Aegean
- Adenauer
- Model you own: w186
Strange as it might seem, 08 48 replaced 09 48, however that was superseded by 16 48 and then 17 48, so there is plenty of choice.
W136 170s W186 300b W180 220s W109 6.3 C107 450 x 2, C107 350, W116 6.9 W124 E320 Cab, W140 S320L CLK 430, W220 S350,
- S Class
- Model you own: w126
Hi guys,
I was battling a similar problem but I re-moulded the missing plastic using a soldering iron on low power using excess plastic from the valve block
Before Adding plastic Sanding level Finished Now if I'd only checked the pump beforehand!
04 SL500
94 Supra Aero Top
93 S420
90 420SEL
85 500SE
94 Supra Aero Top
93 S420
90 420SEL
85 500SE
- Bartman4800
- SLS AMG
Wow!
Mercedes really did go through a dark period around the W140...
That looks like a pump I got with my 35 dollar airbed from K-mart.
Whatever happened to" the best money can buy"
2012 W212 E250CDI
2012 W212 E250CDI
- pina4greg
- E Class
So i can use a 0948 instead.....they seem to be more common....but what about the 1648 do they still fit the older system???
Greg
1992 W140 300se
- Aegean
- Adenauer
Yes, and 1748. If you send me your VIN, I check the specifics of your particular car.
- pina4greg
- E Class
- Aegean
- Adenauer
It looks as though your car was fitted with A1408000448 initially, and if any changes were made, it would have been as follows:
A1408001948
A1408002448
A1408000648
A1408002048
A1408002548
A1408002848
A1408003248
A1408001948
A1408002448
A1408000648
A1408002048
A1408002548
A1408002848
A1408003248
