W123 Lower Door Moulding Clips / Fasteners
michaelc
Post by michaelc » Thu 16 May, 2019 2:55 pm
Hi
There are a number of white nylon clips that push into holes in the car door and secure the trim along the bottom of the door in place
I am unable to find a source of these components - Pelican Parts does not seem to stock them
Any there any other possible stockists???
Many Thanks
Michaelc
kimrh
Re: W123 Lower Door Moulding Clips / Fasteners
Post by kimrh » Thu 16 May, 2019 10:37 pm
Try MBOEMParts in USA
https://www.mboemparts.com
You can by direct from them and pay via paypal
88 Black Euro 560SEC 220kw
tsharkey
Post by tsharkey » Fri 17 May, 2019 11:20 am
I reuse them if I can recover the centre pin from inside the door. Go find a wreck and knock the centre pins in. You will recover quite a lot of them.
I also bought a packet from eBay but the plastic was too soft so I couldn't belt them in. I had to make a set of centre pins to use with the eBay outer clip.
Post by AMG » Fri 17 May, 2019 7:22 pm
henrythirstymerc
Post by henrythirstymerc » Mon 20 May, 2019 6:15 pm
Not OEM but - https://www.atpartsmotor.com/index.php? ... pid=162994
also worth getting - https://www.atpartsmotor.com/index.php? ... pid=155479 in the same order. No more slamming doors
