E220 vs C220 wiring harness
BarringtonBrown
Post by BarringtonBrown » Wed 31 Oct, 2018 5:04 pm
My new E220T is in need of a new engine wiring harness, should one from the W202 C220 fit?
Ideally I'm trying to source any E220 loom that I can repair off the car and then reinstall, instead of paying 600 euro for a new one.
It runs great until the drip tray under the windscreen leaks into the [probably cracked] ECU cable :cussing:
1992 Pearl Grey S124 300TE
1993 Bornite W124 500E
1994 Bornite S124 E220
1995 Azurite S124 E220
Re: E220 vs C220 wiring harness
Post by Ivanerrol » Thu 01 Nov, 2018 10:21 pm
There was a man who fixes MB wiring harnesses based in Sydney.
I've been trying to locate his website but not having much luck :Doh:
Google around.
Meanwhile, I don't think E class and C class harnesses are compatible.
What's worse. I've fixed two. Both were W202's. Both C200's. Both were different. :whistle:
If you are doing the engine harness it's probably a good bet that the throttle body harness is cactus as well :dontknow:
The better news. It's generally the coil wiring which is the offender.
BarringtonBrown
Post by BarringtonBrown » Sat 17 Nov, 2018 8:34 pm
I think most of the engine bay wiring is cactus and there's only so much WD40 I can keep spraying into the engine bay!
I'll search for the Sydney guy. My aircon isn't working and all the brown cables to the aircon relay have melted and fused together so hopefully a new loom would have that working too...
The car drives like a dream otherwise :king:
xbberni
Post by xbberni » Sun 02 Dec, 2018 12:01 am
you will need the coil ires too. Have done it with a SA purchase...challenge is RHD to their LHD air con wire is too short
Get the RHD using your parts nr stuck to the ECU harness 124...………..it's worth the E600~been a smooth 8 yrs since I did mine...cant make any mistakes ás each plug is different!
BarringtonBrown
Post by BarringtonBrown » Fri 25 Jan, 2019 4:15 pm
I found a second hand updated loom so I just need to set out a time to swap them over. Didn't come with the coil wires (they are under the rocker cover aren't they?), so I need to buy some of those.
Seems a waste spending money on the E220 when I really want a 320 TE but it's very nice otherwise and only has 200kms on it.
dhaigh
Post by dhaigh » Thu 14 Feb, 2019 7:55 pm
Laszlo Apathy in Melbourne can source Wiring Looms cheaply. His email: laszloa87@hotmail.com
1988 300CE Coupe
Departed:
1989 300E
1990 MX5
1966 Ford Fairmont
1954 Healey BN1
1972 E-Type V12
etc
