M104 Noisy lifters on startup
ngruzevs
560 SEL
Post by ngruzevs » Thu 04 Oct, 2018 9:18 am
I've just purchased a 300e-24 and noticed on startup for about 60-120 seconds, lifters are quite noisy, but once warm noise goes away. The car has high 314k on odometer, but since 2010 has only done 12K. Since purchasing I have done an oil change using 10w-40 Penrite semi-synthetic oil (full zinc). Seller said car had been used very sparingly for last 8 years, as he had two other cars. I'm just wondering if there's anything I can do to quieten lifters on startup, or are they just worn?
Current Garage
1971 MK2 Jensen Interceptor Regency Red Jeremy
1979 W116 450SE Brilliant Red Metallic Claudia
1987 W126 300SE (SA Delivered) Pearl Grey Matt Oscar
2007 Lexus LS460 Sable Grey Larry
2018 Hyundai i30N Polar White Penelope
benzy53
Re: M104 Noisy lifters on startup
Post by benzy53 » Thu 04 Oct, 2018 4:12 pm
Hi Nick
Please change the oil pressure sensor as discussed. When I come on Saturday we can have a look but we
need a correct reading to go further.
Regards benzy53
ngruzevs
560 SEL
Post by ngruzevs » Mon 08 Oct, 2018 7:50 am
Seems to be all good after a few days of driving. Started up this morning (from cold) and couldn't hear anything. Looks like oil change did the trick.
BTW, oil pressure issue now resolved, replaced sender and now good a full 3 bars of pressure when moving.
Current Garage
dhaigh
Post by dhaigh » Thu 14 Feb, 2019 8:04 pm
Liqui-Moly has released a product called Tappet Stop Noise. It’s an additive designed to clean your lifters, valves, and guides.
I've used it on a Mazda with good results.
Liqui-Moly Synthetic Tappet Stop Noise Lubricant - 300ml. About $18
1988 300CE Coupe
Departed:
1989 300E
1990 MX5
1966 Ford Fairmont
1954 Healey BN1
1972 E-Type V12
etc
See my website: http://myclassiccars1967to2017.blogspot.com.au/ for the complete list!
