CLK500 772.6 transmission problem
PeterQ
Region: Western Australia
Post by PeterQ » Sun 02 Sep, 2018 3:15 pm
Just changed the fluid and filter, plus the 13 pin connector. Now it won't move. Slight drop in revs when you engage R or D, but no go. No fault codes, no warning lights, dashboard resolutely says "No malfunction". Fluid was changed just because I got the car with 220000ks and nothing in the service history to say if it had ever been done. Any ideas?
2003 CLK500 convertible, latest successor to:
2006 W164 ML350 - 1999 S430L - Audi A6 C5 V8
Holden Crewman Cross 6 - Ford Territory - Holden Commodore VZ 6 speed Ute
Mercedes 450SEL 6.9 - Ssangyong Musso 3.2 - Mercedes 450SLC
and a litany of others...
Re: CLK500 772.6 transmission problem
Post by T-Modell » Sun 02 Sep, 2018 4:22 pm
the only idea I have - without knowing - would be, that the electronics of the car needs some sort of a reset, which can only be done with the MB tool. Maybe it has to do with that connector. Otherwise it could be the wrong oil or not enough in it ... you checked the right oil and amount?
PeterQ
Post by PeterQ » Sun 02 Sep, 2018 8:13 pm
I have an icarsoft MB unit and there are no codes showing. We're coming to the conclusion that the filter is not fully home - it was a pig to get installed, very hard to get it in with it's new O ring.
Manya3084
Model you own: w209
Post by Manya3084 » Sun 02 Sep, 2018 10:24 pm
If you haven't cured it with the filter re-seating, it could be the the next 2 issues.
1. Did you remove the valve body when you changed the fluid?
There is a slider pin that needs to seat correctly in the gear shift cog when you reinstall it. The car won't change into any gear without being in the correct position.
2. Your conductor plate maybe on it's way out. Looking through the net, it's a common issue that the conductor plates start to fail resulting in poor, or even no shifting (This part basically links the transmission computer with the solenoids in the valve body).
They can be purchased relatively cheaply from ebay, (I bought mine from aliexpress with connector seal/filter/pan gasket for $120.). Changed mine out last weekend and it only added an extra 30 minutes to the task.
PeterQ
Post by PeterQ » Sat 08 Sep, 2018 3:09 pm
Think I have the answer. I will need a conductor plate because my 13 pin connector only has 12. One is broken off in the connector. I suspect that was why it was already a bit slow going into D, but disturbing it by replacing the connector bit meant there was no longer any connection at all. The old connector came undone easily and the plug pulled from the socket easily, so I doubt it broke then. So now I have to get an immobile car back up onto the ramps.
PeterQ
Post by PeterQ » Sat 08 Sep, 2018 5:29 pm
Now that was weird - got the car up off the ground, removed the drain plug, nothing. No fluid. So where did about 6 litres go? Poured it down the tube at rear right of the engine bay. Specially purchased dipstick says there's oil there, nothing on floor since last weekend, oil on dipstick is pristine and new, so not mixed with engine oil or something else. Any ideas?
PeterQ
Post by PeterQ » Sat 08 Sep, 2018 7:47 pm
Buggar. I just figured it out - 5-6 litres of ATF in the engine. Only now, with the plastic covers removed is the real transmission filler tube revealed. My car does not have a dipstick for the engine, but this tube is where it would go if there was one. Right next to, and far more visible than the correct one for the transmission. I didn't question the difference in the cap on the tube because I've had other parts that don't match what pictures and videos show - I couldn't replace the sway bar bushes because, contrary to the EPS (armed with my VIN), I do not have separate bushes. I had to buy an entire sway bar. I still can't find that in my EPS.
