Diagnostic for messages
- Michel
- C 111
I have a CLK430 and have been getting the odd message flash on my dash.
From being late for a service to ABS and faulty lights.
With the faulty light, obviously i replaced whichever was gone and that fixed that one.
For being late for the service I found a youtube video showing how to reset that.
But yesterday the ABS light and (warnings that i should go immediately to the dearlership) came on and then after stopping and getting abck in the car, it never came back.
However, leaving the office in the evening I realised my brake lights were stuck on.
I felt the pedal and tried to pull it back, but it wasn't that.
Any ideas?
Also, Does the CLK430 have an OBD port? and where?
Many thanks
Any ideas?
Many thanks
Michel (in Sydney)
W116: 1978 450SEL 6.9 - 690SEL # 3312
R107: 1985 500SL AMG - LHD
C208: 2000 CLK430 Coupe
W163: 2003 ML320
W163: 2003 ML320
- Ivanerrol
- Model you own: w204
Re: Diagnostic for messages
If you do have an OBD II port it will be located adjacent the bonnet release. There will be a little cover over it.
However I suspect that you won’t have one. Just the round 32 pin port in the engine compartment.
You will require a higher end commercial variety scanner to access the codes on this port.
OBD standard was late to the party in Australia.
Suspect your brake light switch mounted on the brake pedal
- OZBENZ Admin
Brake lamp switch failure, super common fault. Get a new switch and make sure ot reset it as it is installed as it has an adjustable point at which it is on/off.
- Michel
- C 111
Thank you Ivanerrol and John for the information.
John, is that a common switch or MB unique?
Also when mentioning the about the ESP and ABS warnings, I realised that my cruise control stopped working
Are they all related?
Michel (in Sydney)
W163: 2003 ML320
W163: 2003 ML320
- Christo C
- Pagoda
- Model you own: w124
Cruise Control is usually defeated when brakes are applied; as your brake switch seems to have failed ‘ON’ I suggest Cruise Control thinks brakes are applied...
Beaconsfield, SYDNEY
- OZBENZ Admin
MB specific and various versions based on VIN number
- Aegean
- Adenauer
- Model you own: w186
Send me your VIN Michel and I will look it up.
W136 170s W186 300b W180 220s W109 6.3 C107 450 W116 6.9 W124 E320 Cab CLK 430
- Michel
- C 111
Thank you
Michel (in Sydney)
W163: 2003 ML320
W163: 2003 ML320
- Michel
- C 111
Thanks Craig
WDB2083702F172553
Michel (in Sydney)
W163: 2003 ML320
W163: 2003 ML320
- Aegean
- Adenauer
- Michel
- C 111
Many thanks CraigAegean wrote: ↑Sun 02 Sep, 2018 9:23 amPart number is A001 545 95 09
https://www.ebay.com.au/itm/Mercedes-Be ... 2522378975
Michel (in Sydney)
W163: 2003 ML320
W163: 2003 ML320
