FUEL FILLER DOOR
Jelfes
FUEL FILLER DOOR
Post by Jelfes » Mon 27 Aug, 2018 3:25 am
Does anyone know how to manually open the the Fuel Filler Door from the boot on a 1985 Series 1 190E?
It normally unlocks with the door central locking vacuum system and you push it open. Its not opening at the moment and I'm running low on fuel.
Rollytime
Re: FUEL FILLER DOOR
Post by Rollytime » Mon 27 Aug, 2018 10:48 am
Hey
If you open the boot to can reach the actuator and there is a release rod you pull towards the back of the car.
Hope this helps
Jelfes
Post by Jelfes » Mon 27 Aug, 2018 10:29 pm
Thanks for your help.
Door decided it would unlock this morning.
Post by Ivanerrol » Mon 27 Aug, 2018 11:10 pm
You generally need to remove the boot lining to get at the actuator or at least move it out of the way.
Return to “W201”
