Engine Mounts - right part
petrol_pyro
Post by petrol_pyro » Sun 12 Aug, 2018 5:49 pm
Hi All
I just started the job of replacing the engine mounts in my 1988 300E, and found something odd. The old mounts (part number 201 240 4317) are much shorter than the new ones I purchased (ebay seller prestiege-auto https://www.ebay.com.au/itm/Mercedes-Be ... 3087932525)
Photo is below (new on left, old on right).
Is it just that the old mounts had completely collapsed, or did I get the wrong part? Advice is appriciated
Re: Engine Mounts - right part
Post by T-Modell » Sun 12 Aug, 2018 5:53 pm
if they fit I'd put them in; I remember having rubber parts half the height after 25 years. Strange, that it's a 201-number ... maybe they're the same for W201 and W124 ...
Post by John Green » Mon 13 Aug, 2018 1:05 pm
Totally normal, the old ones have collapsed. These were originally a 201 number as they were used in the W201 190E 2.6. The number has changed a bit obver the years witht he current design spec being A124 240 19 17.
A very "German" fact is that these are differant between a car with and without air conditioning. No doubt some German engineer spent days working out why this was so :think: :think: :think:
Post by Ivanerrol » Mon 13 Aug, 2018 4:22 pm
Proper engine mounts are hydraulic - i.e. are filled with oil.
If the oil leaks out - usually due to old age - seal degradation, the mounts collapse.
Beware of buying el cheapo PRC mounts - they are solid rubber with no hydraulic oil gel. You wont get a proper result with these.
Post by T-Modell » Mon 13 Aug, 2018 4:25 pm
...A very "German" fact is that these are differant between a car with and without air conditioning. No doubt some German engineer spent days working out why this was so :think: :think: :think:
I know the guy. He only needed 3 seconds to find out, that the compressor adds extra weight :laughing6: :laughing6:
petrol_pyro
Post by petrol_pyro » Mon 13 Aug, 2018 8:53 pm
Thanks guys for the advice... very useful and confirmed the difference between a 'non-ac' and 'ac' mount for me.
Now the question.. do you think it makes a rats of difference if I put the non-AC ones (which i have) in the AC car?
Post by T-Modell » Mon 13 Aug, 2018 8:58 pm
Well, the car has a lower centre of gravity then, so cornering in the suburbs of Melbourne might be possible with 1-2km/h more ... :whistle:
petrol_pyro
Post by petrol_pyro » Mon 13 Aug, 2018 9:10 pm
I will take that as a no...
Interesting, Febi Bilstin make two mounts: https://partsfinder.bilsteingroup.com/e ... nsion?f=31
Interestingly the one that the OE parts codes state is NOT for use for aircon, the Bilstein part specifically states it is limited for cars with aircon (FEBI 03428). So if it will fit, it is staying. And I'll corner faster with my lower centre of gravity.
Any suggestions on whether loctite is needed on the engine mount bolts? Or just torque up to 55nm and leave it?
