How to disassembly zenith carbs?
- A Class
Hello, I need to rebuild the zenith carbs of my w111, but I have problems to disassembly them.
Do you know if is it necessary to disassembly the manifolds before? the carbs nuts are very difficult to access and I think is needed to disassembly manifolds.
- OZBENZ Admin
Re: How to disassembly zenith carbs?
To remove the carb's you need to remove the rocker cover. This gives you access to the inner nuts. They are all a PITA to get too, but it is possible to do.
- E Class
Very True about the pain in the ARSE butJohn Green wrote: ↑Mon 06 Aug, 2018 12:26 pmTo remove the carb's you need to remove the rocker cover. This gives you access to the inner nuts. They are all a PITA to get too, but it is possible to do.
after getting the valve cover out of the way take a CHEAP 12 MM wrench preferably a box end and heat it up and bend it to access the nuts closest to head makes it almost a breeze.
- A Class
Maybe using this tool can remove the inner nuts and no need to bend the wrenchHenry Schuman wrote: ↑Mon 06 Aug, 2018 1:51 pmVery True about the pain in the ARSE butJohn Green wrote: ↑Mon 06 Aug, 2018 12:26 pmTo remove the carb's you need to remove the rocker cover. This gives you access to the inner nuts. They are all a PITA to get too, but it is possible to do.
- OZBENZ Admin
No, unfortunately access is too tight to even get a standard ring spanner over the nuts.
- E Class
Yepper that's a neat tool however won't even get close to those nuts unless the manifold is off the Head.
I will try and find my old handmade wrench and take a pick and post in tomorrow.
- A Class
I would very grateful if you post a pic to get an idea, thanks!Henry Schuman wrote: ↑Tue 07 Aug, 2018 1:28 pmYepper that's a neat tool however won't even get close to those nuts unless the manifold is off the Head.
- E Class
Took me a while to find it but here tis.
- A Class
It look like and old tool, I will try to find it. Otherwise I will dissasembly the manifold
- E Class
Well I started working and sometimes repairing Mercedes in 1967 and bent that wrench in @ 1971.
I THINK it was originally a Valve adjustment Wrench for a Subaru
Check the part number on it or Google it and maybe you will find one ?>?
- E Class
Here is a link to a Good tool to have for situations like this but you will need to remove the valve cover probably but not with the tool I made
https://www.toolsource.com/carburetor-t ... e755m6b3u3
- A Class
Yes I will remove the valve cover, maybe I will modify a 12 wrench if I dont find a tool like these. Thanks for your replies.
