Zenith rebuild - Vacuum diaphragm questions...
MajorBenz
Post by MajorBenz » Fri 27 Jul, 2018 1:45 pm
Hi guys,
I’m putting a zenith 35/40 back together, and have a couple of questions about the vacuum diaphragm that operates the throttle on “Stage II”:
1.) Operation:
So my understanding is that there is a little hole inside stage I, that connects via a tunnel through the carb body, up to the top half of the diaphragm chamber. Once enough air is travelling through stage I a vacuum is created in this tunnel that sucks the top of the diaphragm upwards, operating a lever that opens the throttle on Stage II.
Have I got this right?
2.) Testing the vacuum:
Assuming I understand the operation correctly - I should be able to push the connecting rod on the bottom of diaphragm upwards, stick my finger over the little outlet hole on the chamber, and the diaphragm should stay up. I have done this a few times with mine and it appears there is a leak. I think it is around the seam where the two parts of the chamber body come together. Any suggestions how to fix this? Some kind of instant silicone gasket goop perhaps?
Any suggestions/advice appreciated.
Dan
This is the beasty I’m talking about…
Silver 1969 280S - "Grace"
Re: Zenith rebuild - Vacuum diaphragm questions...
Post by Bartman4800 » Fri 27 Jul, 2018 2:52 pm
I am not very familiar with the Zenith carbs (I have solexes)
But if 2 surfaces do not seal (because of warping) you can flatten them in the following way:
Find an old mirror or a pane of glass. Stick on a sheet of sand paper (start with 240 grit)
Move the part over the sandpaper until you have touched the whole surface.
Do this for the opposite part
240 grit should be fine for vacuum but you could do it again with 400 and 600 wet n dry...
Try to avoid using silicone anywhere on your car. It promotes corrosion, looks horrible and any painting in the vicinity will become a nightmare.
If you need to add something to make it seal, use permatex aviation gasket in a jar.
MajorBenz
Post by MajorBenz » Tue 21 Aug, 2018 10:58 am
Hey Bart,
Thanks for your reply. The culprit turned out to be the diaphragm itself. The new one supplied with my rebuild kit was made up of 3 x parts (2 metal bits that come together with the rubber diaphragm sandwiched between) Dropped a bead of instant gasket around the meeting edges of these parts and it did the trick!
Dan
Return to “W108/109”
