SEC & LSD
- OzBenzHead
- 300 SLR
- Model you own: w126
SEC & LSD
Was there an LSD (not the drug!) option for the 500 SEC 2.24 mechanical anti-squat diff?
OzBenzHead
Currently owned:
1965 W112 300 SE/C
1983 C126 380 SEC
2003 BA Falcon ute
and formerly:
1955 W180 220a
1965 W111 220 S
1970 W108 280 SE (my first Benz)
1973 W116 280 SE Crayford Estate (previously owned by Rolf Harris)
1975 W116 450 SE
1980 W116 280 SE
1989 W124 300 E
1992 W201 180 E
1992 W201 190 E 2.0
+ numerous W108 and W116 rolling spares
and prior to my M-B enlightenment:
53 other cars of many nations, but mostly British oil-leakers (including 14 Rovers of the 50s and 60s) cursed by Lucas the Prince of Darkness. First car owned (at age 13): 1953 Fiat. Learned to drive in: 1927 Nash utility paddock-basher & Grey Fergie tractor. Driven distance (logged as at 30 December 2018): 4.7 million km.
Currently owned:
1965 W112 300 SE/C
1983 C126 380 SEC
2003 BA Falcon ute
and formerly:
1955 W180 220a
1965 W111 220 S
1975 W116 450 SE
1980 W116 280 SE
1989 W124 300 E
1992 W201 180 E
1992 W201 190 E 2.0
- T-Modell
- SLS AMG
- Model you own: w107
Re: SEC & LSD
I'm pretty sure, as my R107 500SL has it (2.24) ...
- E Class
Re: SEC & LSD
Yes. Usually if it’s not ASR it’s LSD then.
I have seen open diffs but to me it’s rare find.
LSD=ASD (asd has extra hydraulic pressure for 100% lock up if needed.
Inside is the same. 10pcs of friction discs.
Here’s w124 300-24 asd rear diff. W126 has same diff except the housing.
- Pagoda
Re: SEC & LSD
Hi OBH,
My 500SEC (85) has one. It has the option code for an LSD. Can't remember the ratio, CraigB found it printed on the diff it is certainly 2 .something. It was certainly available at the time, not sure how common it is.
- E Class
Re: SEC & LSD
Diff ratio is nothing to do with lsd option.
500 - 2.24
420 - 2.42
560 - 2.65
All ratios could be with LSD/ASR or open diff as well.
If not asr(snow chain button in dash) then look at differetial rear cover. If there is small metal plate under 2 bolts(or one sometimes) bottom right side (sperr differential) then its LSD.
500 - 2.24
420 - 2.42
560 - 2.65
- kimrh
- 300 SLR
Re: SEC & LSD
All Aussie delivered Gen2 560's came with 2.47 ratio in ASR or LSD
Only private import Euro 300hp 560's came with 2.65LSD as most were out of HK as RHD (some from UK or Japan or S/Africa)
- OZBENZ Admin
Re: SEC & LSD
Yep, I have never seen a gen 1 500 without 2.24 LSD.
Were you thinking of fitting one to your 380? Its a really tall diff and I would be concerned about what it would do for performance and even economy. Personally i think it is too tall even for the 500 and the 2.47 of later 500/560 a much better ratio. 2.65 gives that extra performance though as fitted to the hi comp 560. But then there are other tricks putting gen 2 ratio into gen 1.... do a search, lots of discussion on that!
- OzBenzHead
- 300 SLR
Re: SEC & LSD
Thanks, Gents, for the replies.
I haven't yet been able to crawl under the donor vehicle to check for the LSD markings (it's in a close-packed scrum of cars), but am hoping it is. It's part of a complete 500 drivetrain that I'm considering. My 380 has LSD 2.47, and I'd rather not sacrifice the limited-slip facility if I don't have to.
Cheers :-)
Cheers :-)
OzBenzHead
Currently owned:
1965 W112 300 SE/C
1983 C126 380 SEC
2003 BA Falcon ute
and formerly:
1955 W180 220a
1965 W111 220 S
1975 W116 450 SE
1980 W116 280 SE
1989 W124 300 E
1992 W201 180 E
1992 W201 190 E 2.0
Currently owned:
1965 W112 300 SE/C
1983 C126 380 SEC
2003 BA Falcon ute
and formerly:
1955 W180 220a
1965 W111 220 S
1975 W116 450 SE
1980 W116 280 SE
1989 W124 300 E
1992 W201 180 E
1992 W201 190 E 2.0
- OZBENZ Admin
Re: SEC & LSD
even if you went with 500 motor/trans, I would definitely stick with your 2.47. Its not like it is any weaker or anything and unless you plan on driving on autobahns. My 380SEC has a 3.something LSD and while I don't mind the sprightly nature it gives the car, it isn't as relaxed on the open road. I wrecked a 380sl and was interested to find a 2.47 lsd in it, but maybe that is a more common 380 ratio and this other one is odd?
