Tailgate not locking on S212
Cowleystjames
Post by Cowleystjames » Thu 23 Feb, 2017 5:55 am
Hi guys, my tailgate on my S212 isn't locking when power closed. Out Disney even sound like it's trying to.
However, if I close the tailgate by pushing down, it locks fine
Any ideas?
Re: Tailgate not locking on S212
Post by Ivanerrol » Thu 23 Feb, 2017 9:03 am
Pushing the tailgates down by hand may damage the mechanism.
You may need to get to an independent MB specialists to have this checked out.
Very frustrating feature - push button closure must be used otherwise expensive damage can be done.
Cowleystjames
Post by Cowleystjames » Sun 26 Feb, 2017 10:54 pm
Many thanks for your reply, so frustrating.
ANF
Post by ANF » Mon 27 Feb, 2017 12:36 pm
I imagine very similar to my ML350 power tailgate, sometimes mine does not latch, slight upward pressure on the tailgate from outside (ie; lifting slightly on the handle) will engage the lock. Also most times driving off will move the tailgate slightly and also lock. I have not looked into it such, but figure it just needs minor adjusting, does not bother me that much... one day I will get around to looking at it. Closing manually is quite hard to do, not sure that it will damage it though? No warnings in owners manual?
Cowleystjames
Post by Cowleystjames » Mon 27 Feb, 2017 12:58 pm
If I pull the tailgate down, it moves with no resistance and will shut and latch manually. It will also power down and I can just give it a shove when it fails to lock on that last little bit.
I can't see how I'm damaging anything by doing what I am, and as you said, there's no warning regarding closing tailgate manually
Starman
540 K
Model you own: w211
Post by Starman » Mon 27 Feb, 2017 5:39 pm
From the w212 on-line owners manual, see below. It makes sense because how do you stop people from closing the trunk manually? You cannot.
W212 E400 Avantgarde
W211 E500 Elegance sold
W202 C200 "the Tank" sold
Post by Ivanerrol » Mon 27 Feb, 2017 7:02 pm
Mates CLS Shooting Brake tailgate went faulty.
Stealership fixed it and told him to not close by hand otherwise can damage the mechanism.
It was beuacoup $$$ to fix.
Either the stealership was shirking their responsibilities or there is an issue with these push button tailgates MB is keeping quite about.
