2003 clk 500 balance shaft timing gear problem
mardive
Post by mardive » Sun 12 Feb, 2017 5:20 pm
I am looking at buying CLK 500 2003 I have been reading up on these models, Is this model affected by timing gear and balance shaft problems?
Please help
Re: 2003 clk 500 balance shaft timing gear problem
Post by Ivanerrol » Tue 28 Feb, 2017 6:33 pm
Sorry missed this one.
Timing shaft and balance problems are more drastic in the first of the M272 and M273 engines 2004 - 2008. - 2.8, 3.5 and 5 litre engines.
I would steer clear of any car with these engines in this time frame.
M.B. came under a couple of class actions in the U.S.A. regarding this issue. The first one not successful, the second one successful.
Many TSB's written on this problem.
if you have a failing Timing mechanisms in this country - good luck with it.
Early M112 and M113's suffered from a harmonic balance problem. This was caused (and still is) by leaks from the sensor cover and oil cooler gaskets above the Harmonic balancer. By 2004 this had been dealt with.
ANF
Post by ANF » Thu 02 Mar, 2017 9:54 am
I happily bought my 2005 ML350 with the 3.5 V6. I did read all about the issues that these engines can have and it is a very small minority that do, just as in the 996 Porsche. The internet is full of bad stories and angry owners, not much of the happy, trouble free ones unfortunately.....
Every car made can have issues with it.
