W220 (2000 S320) USB kit
Richard46
Post by Richard46 » Thu 12 May, 2016 7:09 pm
Does anyone know if a USB/memory card/iPhone kit is available that connects to the command stereo system in the W220?
Richard
Re: W220 (2000 S320) USB kit
Post by Ivanerrol » Fri 13 May, 2016 9:11 pm
AFAIK.
The only phone that was originally compatible back in those days was a MB supplied Nokia. They (the stealerships) wanted big bucks for the phone and the unit that connected this phone with the Command via the fibre optic bus system.
When I bought my W209 in 2004 there was a prewired phone cradle in the central armrest. The stealership wanted some ungodly amount of money for a Nokia dumbarse phone that was years out of date and available on eBay for $50.00.
Even if I bought my own handset there was going to be a big service charge to match it to the Canbus system.
Call up Soundlabs.com.au. I suspect that they will have something compatible. Nowadays there are hacks.
Les Orth
Model you own: w220
Post by Les Orth » Wed 18 Jan, 2017 3:21 pm
If you are still in the market for a device to connect a USB / memory card or iPhone to your command system, there are several options available. I am in the process of doing this myself and will keep you posted as to what I finally decide to do.
The options are to buy a device to connect into the existing sound system or replace it with an aftermarket unit that connects into the fibre optic amplifier connections. All options are advertised on eBay, then just google reviews on each. You can achieve what you want to do from as little as $20......
At this stage I'm favouring the complete after market unit as this gives me an up to date GPS system as well and I can get free map updates. There are two brands I'm considering, Xtrons and Erisin, both are android systems with good reviews.
The main thing is you can achieve what you want to do with several options available.....from as little as $18.89 so don't think it is expensive.
Les
1962 220SE
1969 280SE
1968 300SEL
1965 250SE
1983 380SEL
1994 E220 - owned at same time as 300SEL (much preferred the S class) sold
1990 300SEL - Interior - mushroom (265) Paint 512 almandine red - 170000 klms when sold
2004 S350 - Current Car - Interior light grey - paint chalcedony blue 120,000 klms bought Dec 2016
