Headlight Switch Wiring Colour Code
nvrau
Model you own: w168
Post by nvrau » Sun 04 May, 2014 4:47 pm
Anyone have a wiring colour code to share for the headlight switch?
Re: Headlight Switch Wiring Colour Code
Post by John Green » Sun 04 May, 2014 9:06 pm
That sounds like you have had a switch plug explode in your hands? We could cut one from a wreck for you?
nvrau
Model you own: w168
Post by nvrau » Mon 05 May, 2014 6:28 am
John Green wrote:That sounds like you have had a switch plug explode in your hands? We could cut one from a wreck for you?
Thanks for the reply!
No problem with my switch. I am looking for the colour code as I am about to install a remote start alarm on the car.
Since this post I was able to find a little information on other MB's, so I may be able to muddle my way through. If someone has the exact info that would be great!
nvrau
Model you own: w168
Post by nvrau » Mon 12 May, 2014 10:05 pm
For those who may be interested in this one day, I have a partial colour code for 2002 A160 Classic Auto (W168) after metering the plugs. My car has three plugs at the switch assembly (I had no need to know which was left/right on headlights):
Black Plug (1 PIN)
1) BLK/YEL (+) Battery 12V
Blue Plug (10 PIN)
1) Empty
2) YEL (+) Front Headlight
3) Empty
4) 2/GRY/YEL (+) Front Fog
5) Empty
6) YEL/BLK (+) Front Headlight
7) WHT/BLK (+) Headlight High-Beam (With Ignition on)
8) GRY/RED (+) Front Right Park/Running
9) GRY/BLK (+) Front Left Park/Running
10) WHT (+) Headlight High-Beam (With Ignition on)
Burgundy Plug (10 PIN)
1) BLK/ORG (+) Ignition
2) BRN (-) Ground
3) GRN/WHT (+) 12V (Until ignition is on)
4) GRY/GRN (+) Rear Fog
5) WHT (+) Headlight High-Beam (With ignition & headlights on)
6) WHT/BLK (+) Headlight High-Beam (With ignition & headlights on)
7) 2/GRY/PUR (+) Dash and Lights-On Warning Buzzer
8) GRY/BLK (+) Rear Left Park/Running
9) WHT/YEL (+) Headlight
10) GRY/RED (+) Rear Right Park/Run
Please share any corrections!
