New 6.9 purchased
m48pro69
Re: New 6.9 purchased
Post by m48pro69 » Tue 31 Mar, 2015 10:20 pm
Yes they will be added . Bolt holes still to be drilled as per 3d picture.
m48pro69
Post by m48pro69 » Thu 02 Apr, 2015 12:02 am
Ok 3 throttle bodies have been machined this is what they currently look like . Image
m48pro69
Post by m48pro69 » Sun 12 Apr, 2015 11:47 pm
Apparently this is my Dkubus FrankenCIS WUR ready for shipping. My throttle bodies will be finished by end of next week as well. I have been told.
TJ 450
Post by TJ 450 » Mon 13 Apr, 2015 1:57 am
Very nice indeed...
I reckon I'm going to have to bite the bullet and get one of these Dkubus FrankenCIS setups to cure my 6.9's injection woes once and for all.
Tim
1976 450SEL 6.9 1432
1979 450SEL 6.9 5866
1969 300SEL 6.3 1394
m48pro69
Post by m48pro69 » Mon 13 Apr, 2015 2:24 pm
Hi Tim you can inspect it before I fit it ok.
m48pro69
Post by m48pro69 » Tue 21 Apr, 2015 9:15 pm
Throttle bodies are now made will have by the end off the week.
Post by kimrh » Thu 23 Apr, 2015 9:12 am
They turned out nice Geoff
How is the engine coming along
By the way when i spoke to someone at Southside Engines Builders a couple of years ago (can't remember his name) he mentioned to me that the can handle the MB Alusil alloy blocks for reconditioning the bores with the required machining/etching process with the special pads and paste to re-etch the cylinder walls after boring.
When you are next there speaking to them about you engine -can you please ask / re-confirm that they can still handle the Alusil M117 alloy blocks for boring/re-etching the silicon crystal impregnated cylinder walls after they are bored out
I still want to take a block to them for boring out to either 98mm or 100mm as a project engine with custom lightweight forged pistons to match
Cheers Kim
m48pro69
Post by m48pro69 » Thu 23 Apr, 2015 6:15 pm
Ok will do but Southside do machining for other engine shops in Perth so I would think that would still be the case.
m48pro69
Post by m48pro69 » Mon 04 May, 2015 6:45 pm
Ok the throttle bodies arrived today. Still waiting for FrankenCIS and word on my motor. But will be going back to W.A this weekend to check up on my car. Image Image Image Image Image
m48pro69
Post by m48pro69 » Sun 17 May, 2015 12:27 am
Slight issue with fitting billet throttle body is Australian has blade fitting on end of shaft Euro has a round fitment . So will send 1 throttle body back to be fixed . Measurements taken and email sent to Dave in Melbourne. Also car has been dropped of at Rowe and Sons for paint job. Parts have been ordered from Mb Spares more to follow as its a back to metal paint job.
m48pro69
Post by m48pro69 » Tue 19 May, 2015 9:51 pm
My FrankenCIS WUR from Dkubus arrived yesterday will fit it and 85mm throttle body after paint is done and will dyno results.
To this list off brand new genuine parts
1x Set front and rear Genuine window seal
1x Set of Genuine door seals
12x Clip front door seals
10x Clip rear door seals
1x Front sunroof seal
2x Side sunroof felt
1x Rear sunroof seal
1x Boot seal
2x Boot lid bump stop
8x Window felt (inner and outer)
2x Fuel flap bump stop
1x RHF indicator assembly
1x LHF indicator lense only
Now add
1x RHR Taillight assembly
1x LHR Taillight assembly
1x Centre Grill section
I think it should look ok when finished as long as I don't lift bonnet as I have not painted that at this stage.
V8Finny
Post by V8Finny » Mon 02 May, 2016 10:24 pm
Any update here?
69 W109 300SEL 6.3 #2462
52 Ford Pickup
m48pro69
Post by m48pro69 » Thu 31 Jan, 2019 4:32 am
There has been no updates on this car because after having a drunk driver crash into me in 2016 . Finances have been tight and all work was stopped. I am hoping to recommence work on this car in a few months time
Post by T-Modell » Thu 31 Jan, 2019 7:11 pm
I hope you have properly recovered and I wish you good luck in continuing your project.
V8Finny
Post by V8Finny » Sat 02 Feb, 2019 5:08 pm
People ask me what I'm doing with my 6.3.....
I tell 'em "Owning it......owning the faeces out of it!!"
Your day will come.
Always one of the more inspirational builds on here!
52 Ford Pickup
Return to “W116”
