OM617 new head gasket compression bench test
Dweezil
Post by Dweezil » Thu 09 Aug, 2018 7:34 pm
Hi Team,
I've put a reco head and gasket onto Jurgen's block.
Is there a 'bedding down' period where I should let things settle before doing a compression test to see whether it's worth sticking back into Jurgen?
Dweezil
Henry Schuman
Re: OM617 new head gasket compression bench test
Post by Henry Schuman » Thu 09 Aug, 2018 11:01 pm
As long as you have the Head bolts torqued correctly ,engine in Time, and the Valves adjusted properly you can spin it over anytime .
Post by John Green » Fri 10 Aug, 2018 12:58 pm
Things would have to be spectacularly wrong to have compression issues with a new gasket. So long as both surfaces were clean and straight and it is torqued down correctly it should be fine. This is not a check that I would do, just get on with starting it and have it back on the road in time to bring to the OZBENZ Meet :dance:
Henry Schuman
Post by Henry Schuman » Sat 11 Aug, 2018 2:01 am
I agree Mr. Green however,
I Don't know why he pulled the Engine to put on a Head gasket in the first place BUT IF one has any doubts of their expertise in Head gasket /Head Replacement then Now WOULD be a good time to do Preliminary checks such as Compression Test, OIL Pressure Test,Oil Leaks ,etc before installing back in the Bay.
Dweezil
Post by Dweezil » Sat 11 Aug, 2018 11:47 am
Thanks, gents.
The way everything else has gone on this little project, caution (and the preservation of my sanity) would suggest that a compression test would be a good idea.
Do I need to do anything beyond hook up the oil cooler lines to and from the oil filter, fill with the right amount of oil and apply 12V to the starter? Is there earthing I need to pay attention to?
Thanks again.
Dweezil
Dweezil
Post by Dweezil » Sat 11 Aug, 2018 11:51 am
Oh, it's worth pointing out that this is a replacement block - Jurgen's orginal had a bit of piston slap, the IP was marginal and the main chain tensioner rail had broken in two, so I thought I may as well use the spare that looked a better bet.
Dweezil
