How to disassembly zenith carbs?
heiwaz
Region: Australian outlaying islands-Territories
Post by heiwaz » Sun 05 Aug, 2018 7:14 am
Hello, I need to rebuild the zenith carbs of my w111, but I have problems to disassembly them.
Do you know if is it necessary to disassembly the manifolds before? the carbs nuts are very difficult to access and I think is needed to disassembly manifolds.
Re: How to disassembly zenith carbs?
Post by John Green » Mon 06 Aug, 2018 12:26 pm
To remove the carb's you need to remove the rocker cover. This gives you access to the inner nuts. They are all a PITA to get too, but it is possible to do.
Henry Schuman
Post by Henry Schuman » Mon 06 Aug, 2018 1:51 pm
Very True about the pain in the ARSE but
after getting the valve cover out of the way take a CHEAP 12 MM wrench preferably a box end and heat it up and bend it to access the nuts closest to head makes it almost a breeze.
heiwaz
Post by heiwaz » Mon 06 Aug, 2018 9:50 pm
Maybe using this tool can remove the inner nuts and no need to bend the wrench
Post by John Green » Tue 07 Aug, 2018 7:39 am
No, unfortunately access is too tight to even get a standard ring spanner over the nuts.
Henry Schuman
Post by Henry Schuman » Tue 07 Aug, 2018 1:28 pm
Yepper that's a neat tool however won't even get close to those nuts unless the manifold is off the Head.
I will try and find my old handmade wrench and take a pick and post in tomorrow.
heiwaz
Post by heiwaz » Tue 07 Aug, 2018 5:35 pm
I would very grateful if you post a pic to get an idea, thanks!
Henry Schuman
Post by Henry Schuman » Wed 08 Aug, 2018 1:30 pm
Took me a while to find it but here tis.
heiwaz
Post by heiwaz » Wed 08 Aug, 2018 6:06 pm
It look like and old tool, I will try to find it. Otherwise I will dissasembly the manifold
Henry Schuman
Post by Henry Schuman » Thu 09 Aug, 2018 1:01 am
It looks like an old tool, I will try to find it. Otherwise I will disassemble the Manifold.
Well I started working and sometimes repairing Mercedes in 1967 and bent that wrench in @ 1971.
I THINK it was originally a Valve adjustment Wrench for a Subaru
Check the part number on it or Google it and maybe you will find one ?>?
Henry Schuman
Post by Henry Schuman » Thu 09 Aug, 2018 11:04 pm
Here is a link to a Good tool to have for situations like this but you will need to remove the valve cover probably but not with the tool I made
https://www.toolsource.com/carburetor-t ... e755m6b3u3
heiwaz
Post by heiwaz » Fri 10 Aug, 2018 9:16 am
Yes I will remove the valve cover, maybe I will modify a 12 wrench if I dont find a tool like these. Thanks for your replies.
