Highbeam adjustment?
brette013
Post by brette013 » Fri 15 Sep, 2017 4:34 pm
HI people,
I just want to ask is there any way to realign the low and high beams to be together on a 300ce-24? On mine, the high beams are currently pointed upwards and the low beams are dead centre like it should be. I understand my levelling switch inside the car isn't working and know I can adjust from behind the headlamps, but adjusting manually moves them both at the same time which is not what I want. Any tips or do I need to fix the levelling switch in order to resolve this?
brette013
Re: Highbeam adjustment?
Post by Tony From West Oz » Fri 15 Sep, 2017 4:44 pm
No, I believe that they have a double filament lamp and the lamp moves with the reflector during under bonnet or remote adjustment.
brette013
Post by brette013 » Fri 15 Sep, 2017 5:03 pm
So I guess I was on the money that it adjust both of them at the same time, thanks for clearing things up. Just thought there might be some secret adjuster lying around somewhere...
brette013
crazycrowbar
Post by crazycrowbar » Fri 15 Sep, 2017 10:10 pm
Hi Mate
While you busy with the headlights, check out this link......
I did mine as per this tutorial and the improvement just by adjusting
it to the correct angle is absolutely phenomenal.....
https://www.youtube.com/watch?v=qDudMM4J-ZE
Hope you find this handy
P
