CLK500 Rattle on start up
gassit320
Model you own: w209
Post by gassit320 » Thu 31 Mar, 2016 7:33 pm
Hi all
I realise this is not a handyman fix issue but I guess it would help me to know if anyone else has had this and/or if they've had it repaired.
Occasionally (about 1 in 20 starts) there is a rattle when the car first starts, usually when its cold and lasts only a second, from speaking to my mechanic it sounds like it could be the timing chain tensioner, extremely annoying as the car is 1 owner, FSH and under 90K !!
Any input greatly appreciated
AMGC36
Re: CLK500 Rattle on start up
Post by AMGC36 » Thu 31 Mar, 2016 9:28 pm
Hi
Check that the right oil is used ??
Cheers Stefan
1995 W202 AMG C36
gassit320
Model you own: w209
Post by gassit320 » Fri 01 Apr, 2016 10:26 am
Thanks Stefan, yes I am going to get the oil and filter changed soon, even though it's apparently 8000Ks to the next service.
gassit320
Model you own: w209
Post by gassit320 » Wed 13 Apr, 2016 2:32 pm
Changed the oil and filter, according to my mechanic oil was fine but very thin, they may have gone with 0W40 which (on research) is really for new engines and very cold weather. I have gone to 5W50 mobil 1 and the engine seems (?) quieter and haven't had the rattle since, fingers crossed
Post by Ivanerrol » Wed 13 Apr, 2016 9:56 pm
Stick to the M.B. recommended spec - i.e. Mobil 1 0-40W.
These engines are intolerant of the incorrect recommended oils and infrequency of oil changes.
Forget the output of the cluster indications of service intervals.
Change the oil every 10K's or at least after 9 months irregardless of the K's. The MB specified oil filters specified for these engines are mad of fleece and not paper or cardboard. Don't skimp on the filters.
The M112 and M113's operate at very high temperatures for emission reasons and the oils must be top notch to compensate.
I have a garage queen M112 engine. It does 8 - 10 K's per year which the majority of is taken up of trips between Melbourne and Noosa return. I change the oil after every trip regardless. If I hear overhead noise
on startup the oil gets changed tout de suite.
