Internal sill coating
Mick_Marsh
Post by Mick_Marsh » Tue 12 Jun, 2018 11:22 pm
Has anyone coated the inside of their sills?
If you did, what did you use and how did you do it?
1965 W112 300SE Heckflosse
1970 W109 300SEL 3.5
efirestorer
Model you own: w180
Re: Internal sill coating
Post by efirestorer » Wed 13 Jun, 2018 2:43 pm
Mick , best way , as I did many years ago - drill access holes in concealed/closed in sections ( ie sills ) then have bare shell dipped to remove all paint/rust and after final painting spray cavity wax in through the access holes. If not prepared to dip , you may get away with cavity wax but you could be spraying it on to rust that may continue rusting under the wax. Not many places do a good dipping job now. If in South Australia , look up MINUS PAINT on web.
