M127 valve stem seals?
Shoudaboughtacoupe1965
Post by Shoudaboughtacoupe1965 » Thu 01 Mar, 2018 2:43 pm
Hello folks. If my car is blowing smoke and my dip stick is constantly being pushed out of it's tube, I suspect my valve stem seals are no longer doing their job? If they need doing how hard is the replacement process on a M127 engine? I should add that watching youtube is the closest that I have ever come to tackling this type of job!! Cheers Corrado
1965 W111 220SEB Sedan
1966 250SE W108 (Rusted out but haven't the heart to put to sleep)
1962 220S W111 Sedan (sold 1995)
Re: M127 valve stem seals?
Post by Bartman4800 » Thu 01 Mar, 2018 4:59 pm
I am afraid renewing your valve stem seals will have little effect.
You have excessive blow-by, caused by worn piston rings and or bore.
There could be a small chance that your sump vent (on top of the cam cover) is blocked, check that first...
Post by Shoudaboughtacoupe1965 » Fri 02 Mar, 2018 10:10 am
G'day Bart. Many thanks for your reply. Any chance you could dig up a picture of the sump vent? Cheers Corrado
Post by Bartman4800 » Fri 02 Mar, 2018 1:21 pm
https://en.wikipedia.org/wiki/Mercedes- ... engine.JPG
It's the left most black hose that comes off the rocker cover (angled 90 deg)
There is a small hole underneath it, in the bushing. It could be filled with crud stopping the vent to work.
Post by Shoudaboughtacoupe1965 » Sat 03 Mar, 2018 10:29 pm
Thanks Bart. The tube looks quite clean so I suppose it's time to think about rebuilding!
