Oil pressure
dynamike
Oil pressure
Post by dynamike » Thu 23 Nov, 2017 9:38 am
I recently noticed my oil pressure drops to 40 (from 45 max) when I'm in gear and stopped. As soon as I rev the engine or shift into neutral it goes straight back up to 45. My initial thoughts were idling speed too low but considering it's going up in neutral I'm not so sure.
Couple of possibly related notes:
I only noticed it this week but it's possible this has been happening for a while
I minimally adjusted the idling and mixture screws on my Zenith carburetors last week.
Engine may have overheated for less than 5 minutes after coolant change and thermostat not opening in time a couple of weeks ago.
1965 220 Sb Sedan
Re: Oil pressure
Post by Bartman4800 » Thu 23 Nov, 2017 10:22 am
The oil pressure needle should be pegged to the top when the engine is cold (idling or revved up)
When the engine is warmed up (and the oil is thinner) the pressure is allow to drop when idling. Nothing to worry here.
It should rise to full again when you increase the revs.
dynamike
Re: Oil pressure
Post by dynamike » Thu 23 Nov, 2017 1:48 pm
Thanks Bart. That's reassuring. What engine oil are you using for yours? I'm currently going with Shell HX3 20W-50.
1965 220 Sb Sedan
sebada
Re: Oil pressure
Post by sebada » Fri 24 Nov, 2017 12:31 am
Bart is right.
Another thing that happens with oil pressure is that oil viscosity decreases with use beacuse of additive shear and fuel contamination, so it's normal to have less oil pressure when the oil has some kilometers of use.
