Carb Nozzle fuel leak
dynamike
Post by dynamike » Sat 09 Sep, 2017 9:14 am
Took the car out after changing the engine mounts and noticed a smell of smoke. Thought it was just grease burning off the exhaust but noticed a fuel leak near the carburettors as per photo below.
Any thoughts on why it would be leaking there? From the diagram it looks like there's a diaphragm - could that be it? Also, I assume once I drain the fuel line to work on it there wouldn't be any pressure pumping more fuel through?
1965 220 Sb Sedan
Re: Carb Nozzle fuel leak
Post by Tony From West Oz » Sat 09 Sep, 2017 11:23 pm
While I do not know what the item below the banjo fitting is, I do know that Banjo fuel fittings sometimes do leak.
Before doing anything else, try just tightening the bolt a little (no more than 1/12th of a turn) and see if the leak is fixed.
If it does not fix the leak, then replace the copper (aluminum) washers on each side of the banjo fitting (where the fuel hose connects to).
They are cheap and easy to replace.
If the fitting still leaks, you may need to check the device in the bolt head.
dynamike
Post by dynamike » Sun 10 Sep, 2017 6:20 pm
Thanks for the reply. Took it out to have a closer look today and everything looked fine. Tightened it all back up and no more leak.
Still curious as to what the actual function of it is? Increase fuel pressure when accelerating hard?
1965 220 Sb Sedan
Post by Tony From West Oz » Sun 10 Sep, 2017 9:31 pm
This looks like a valve that is actuated by the float in the carby float chamber. When the level is low, the float falls, pushing down on the pin, opening the rubber valve, which allows fuel into the float chamber, the float rises and the valve closes again.
Post by Mercmad » Mon 11 Sep, 2017 11:55 am
Fuel return valve, when idling it opens and excess fuel returns to the tank. Open the throttle and it closes giving more fuel to the carbs. it's basically there to prevent vapour locks
Post by Tony From West Oz » Mon 11 Sep, 2017 6:20 pm
You learn something every day.
Post by Bartman4800 » Sat 16 Sep, 2017 6:40 pm
To add a bit of info: the diaphragm will perish over time but is now available through mbclassics.de or ruddies Berlin.
