White Smoke - 220Sb
dynamike
White Smoke - 220Sb
Post by dynamike » Mon 12 Jun, 2017 11:18 am
So I noticed white smoke coming out of the exhaust of my new 220Sb. Uploaded a video of it here
Searching the forum I found some comments about brake booster and vacuum hose leaking into intake manifold so will have a look at that tonight. Any other ideas?
1965 220 Sb Sedan
eddie
Model you own: w210
Re: White Smoke - 220Sb
Post by eddie » Mon 12 Jun, 2017 11:27 am
Looks like it's water vapour, was that when cold? Just after starting?
When the booster lets go the u can't even see through the smoke cloud!! The neighbourhood would call the fire department.
1998 W210 E240 - yawn, but like a tank
1969 Fiat 124 sport coupe - sold it...bit sad but onwards and upwards
1965 W111 coupe 220seb
dynamike
Post by dynamike » Mon 12 Jun, 2017 12:02 pm
eddie wrote:Looks like it's water vapour, was that when cold? Just after starting?
Yes, from cold but didn't seem to improve as engine warmed up. Only had it going about 5 mins this morning though.
1965 220 Sb Sedan
Post by Mercmad » Mon 12 Jun, 2017 3:24 pm
We have had cold wet weather lately. it looks like water vapour from condensation in the muffler. You must never start the engine then shut it off unless you get it warmed up properly (180 on the gauge) it not only causes plug fouling because the cold start mech is running the engine rich but you will wreck the inside of the mufflers with moisture. get it hot then see if it is still steaming. it can take 45 minutes sometimes to get everything nice and warm. Unlike modern cars which have electronically controlled fuel systems our cars rely on 20th century technology and have to be driven, not just steered around the place. : :laughing6:
Post by Bartman4800 » Mon 12 Jun, 2017 5:35 pm
+1 on the water vapour.
White smoke would linger around a lot longer.
Listening to the engine sound it runs better than a lot of them!
starman61
Post by starman61 » Mon 12 Jun, 2017 9:38 pm
Sorry but the video won't load for me. (Internet is crappy at the moment).
Another possible cause, if the vehicle is an automatic, is that the modulator diaphragm on the transmission may have ruptured and ATF is being sucked into the intake manifold and burnt.
I had this happen on my w108 and it can be quite alarming to see (my garage filled with white smoke on start-up), however, replacing the modulator fixed it immediately.
Hopefully, it is water vapour as the others said but just wished to indicate an alternative.
Good Luck,
Bill
'65 W111 220SB
'72 W108 280SE 3.5
'79 R107 450SL
'84 W126 380SEC
'98 R129 SL280
'10 Sprinter 318CDI
dynamike
Post by dynamike » Tue 13 Jun, 2017 9:27 am
Thanks for all your replies. I'll give it a longer ride once the rain subsides and will see how it goes when completely warmed up.
1965 220 Sb Sedan
dynamike
Post by dynamike » Mon 19 Jun, 2017 5:03 pm
Started it up this morning when it was a lot warmer and less humid and no smoke at all. So conclude it was condensation. Thanks for everyone's replies!
1965 220 Sb Sedan
dynamike
Post by dynamike » Tue 03 Jul, 2018 7:52 am
Bill
Opening this thread again as this time I got a white smoking machine that's clearly not condensation...
Thought I had a blown head gasket but going by some preliminary testing and Atf fluid loss I think it might be the modulator as per Bill's comment above. Will run a proper leak down test this weekend but in the meantime a few questions.
To test, is it just a matter of checking the vaccum hose for fluid residue?
Can it be changed without pulling the transmission.
Also, do you happen to know the part number?
Mike
1965 220 Sb Sedan
eddie
Model you own: w210
Post by eddie » Tue 03 Jul, 2018 9:12 am
Hey Mike,
If it's ATF being sucked into the manifold the smoke cloud would be seen from the international space station, it really properly white smokes all over the place. It also gets sucked into cylinder no.6 more than the others so check the rear spark plug and see how wet it is. If the plug is normal it's likely to be something else.
All the best
dynamike
Post by dynamike » Mon 09 Jul, 2018 7:55 am
Confirmed it was the modulator over the weekend. As you described, spark plug on cylinder 6 was really moist, and when I pulled the vacuum line ATF streamed out.
Still did a leak down test too and noted all cylinders were loosing around 45% most likely through the intake valves, possibly some through the exhaust but pressure was probably too low to notice on the exhaust.
That value seems rather high because the engine still runs smoothly. Might be partly due to the cheapish leak down tester kit too.
Does anyone know what is still an acceptable result on a leak down for an unrestored 53 year old M180 engine?
1965 220 Sb Sedan
rens1976
Model you own: w110
Post by rens1976 » Tue 10 Jul, 2018 4:32 pm
45% is a lot of leakage. Remember that it can be masked by things like bad timing or gasket leaks, but it does suggest there are issues.
