parts wanted
ekdave
parts wanted
Post by ekdave » Tue 23 May, 2017 4:50 pm
im aftwe replacement Guards for my w111 or if manufactured part panels in victoria
any leads would be helpful before I repair the ones I have
thanks David 0411289330
Re: parts wanted
Post by AMG » Tue 23 May, 2017 9:29 pm
Forum Sponsor or Mercmad here on the forum would be a good place to start ;)
Re: parts wanted
Post by Mercmad » Wed 24 May, 2017 10:11 am
Unless you want to spend mega bucks check out the best used ones you can find then get them repaired. Which means, apart from accident damage, make sure the ones you look at are not too badly rusted at the rear sill section and above the headlight bucket . The rear part is easily fixed, not so much the headlight end. DBdepot in Germany occasionally has NOS ones for sale but the price is understandably high.
Re: parts wanted
Post by Bartman4800 » Wed 24 May, 2017 10:22 am
Make sure you tell them it is either a Sedan or Coupe/Cab because they are quite different.
Re: parts wanted
Post by Mercmad » Wed 24 May, 2017 10:24 am
ha ha sure are.
ekdave
Re: parts wanted
Post by ekdave » Wed 24 May, 2017 6:56 pm
thanks Guys I did try the site sponsor but no luck ..
been a metal shaper making the parts is not a big issue .. it also seems there could be a market for patch panel,
how many w111 where made ?
are they restored or on the less desirable list ?
thanks David
Re: parts wanted
Post by Bartman4800 » Thu 25 May, 2017 10:33 am
They are surely restored.
Mine is under a (very slow) resto process.
Mercmad is restoring a W112 (300 SE lang) for another Ozbenz member
The coupe's and especially the cabriolet's are more valuable.
In Australia the Sedan's are not very valuable yet, but that could change soon.
You can still buy them cheap. But don't make the mistake of buying the cheapest one - it will turn out the most expensive.
In Europe they cost a lot more, because they rot so much harder there.
If you want to know more about the noble finnie, spend a few hours reading here:
http://www.heckflosse.nl/HistoryHome.htm
ekdave
Re: parts wanted
Post by ekdave » Thu 25 May, 2017 7:22 pm
thanks Bart, yeah I think I have the rustiest one now .. 2k hmmm
a close exam once home reveals heavy filler in all panel including the roof ..
so we the std rust spots .. front bumper supports, both gurads headlight area and lower section ,, both sills
both of all doors .. boot floor .. front floor where it connect to fire wall ..
roof has several dents that have been filled with filler in some areas up to 10 mm think ..
I'm not game to have it sand blasted but I'm sure there more to come ..
still in 2 minds as to keep it or part it our ..
a look at the site shows I have a 220sb motor (180941)
and s 220seb frame ..
also the column shift had been disconnected and it has a 4 on the floor setup .. not sure what that's from atm
Re: parts wanted
Post by Bartman4800 » Fri 26 May, 2017 11:37 am
I don't want to disappoint you, but you are describing 4000 dollars in sheet metal alone, before it is even welded in. You probably need a rotisserie to rebuild the body.
I just sold some aftermarket sills to a member who is restoring the 300SE lang (a far rarer car than what we have).
I still have OEM floor sitting in my shed.
I have a donor car as rotten as yours, I thought about restoring the body but bought a better one (hence the floors and sills)
You should be able to find a proper body with a rotten engine or a dodgy GM conversion.
Keep your 4 on the floor setup, this is quite sought after. The the linkage is unique and I thought the gearboxes have a different top cover.
ekdave
Re: parts wanted
Post by ekdave » Fri 26 May, 2017 5:25 pm
Thanks Bart, I did notice the silly prices for patch panels os . the equivalent holden or ford sill is about $100 bucks M B $900 landed ..
lucky 4 me I have a shop full of metal shaping equipment bead roller , English wheel . pull max etc so making then is not a big issue infact its an enjoyable challenge , clearly the time and expense spent on the project makes it very costly option even making my own part .. but that what I do for entertainment in my retirement ..
ill post so pics when I get to 5 post .. most would run from this basket case
Reards David
Re: parts wanted
Post by Bartman4800 » Fri 26 May, 2017 5:32 pm
Do not forget the jacking points when you open up the sills.
Usually when the sills are gone, the jacking points are rotten too.
You can buy them quite cheaply (repro), the have a reinforcement welded around them.
The sills have a lot more elaborate shape than a contemporary Holden or Ford.
merc-304
Re: parts wanted
Post by merc-304 » Fri 26 May, 2017 5:45 pm
ekdave wrote:Thanks Bart, I did notice the silly prices for patch panels os . the equivalent holden or ford sill is about $100 bucks M B $900 landed ..
Reards David
Hey dave just post Hi there ...anywhere a couple of times to get your posts numbers up....I need to see your pics .
380 SEC
ekdave
Re: parts wanted
Post by ekdave » Fri 26 May, 2017 6:06 pm
ah replies to post don't seem to count but I have reached 5 post .. so ill just have to work out how to upload pics .. and ill confirm that I'm nuts undertaking THIS one , lol
ekdave
Re: parts wanted
Post by ekdave » Sat 03 Jun, 2017 10:11 pm
ok can anyone point me toward so w111 guards have seen any about yet ,,
mine a very sad just removed the drives 1 .. had to cut part of it off .. was welded to inner guard during a prev repair ..
patch weld on nose a some point ..
WELL THAT SUCKS PHOTOBUCKET CHARGE NOW IF YOU WANT TO SHARE YOUR IMAGES :angryfire: :angryfire: :angryfire:
the body line on bonnet side is also heavily filled too .. must be 4 lts of filler in each panel
cut out section to release guard from inner panel ..
total mess she is and that just the start lol
Re: parts wanted
Post by Bartman4800 » Tue 06 Jun, 2017 11:51 am
Dave,
I have a pair of front mudguards for a W111 Sedan
They were sandblasted by me in 2009 and coated with epoxy primer inside and out.
They have some rusted pinholes on the edge where they are bolted to the inner fender, but that's all apart from some surface rust from storage.
There was no bog on them to begin with.
Can provide pictures if you are interested.
I would like 250 each + shipment, but I am in WA
I also have a LH and RH floor, original Mercedes with stickers still on them. Still in black shop primer.
If you are interested, I can find out what I paid for them in Germany in 2013.
HOWEVER!
As I said before If I was in your shoes I would find a better body first and use this one as a donor car.
My donor car is in far better state than your resto object....
ekdave
Re: parts wanted
Post by ekdave » Tue 06 Jun, 2017 10:03 pm
thanks Bart pm sent
Re: parts wanted
Post by Mercmad » Sat 10 Jun, 2017 11:04 am
i'm doing one right now which is as bad as that .
Re: parts wanted
Post by Bartman4800 » Thu 29 Jun, 2017 10:59 am
This one looks a lot better to restore:
http://www.lawsons.com.au/asp/fullcatal ... 96&image=0
ekdave
Re: parts wanted
Post by ekdave » Sun 02 Jul, 2017 5:02 pm
ah yes buying a restored car would be easier but $$ are to high for me and i got its because i enjoy the resto process and know whats been done apart from the butched guards the rest if fixable .. but im yet of fine a parts local .. have had a set in QLD and WA offered
ekdave
Re: parts wanted
Post by ekdave » Sun 02 Jul, 2017 7:28 pm
dynamike
Re: parts wanted
Post by dynamike » Tue 04 Jul, 2017 1:20 pm
ekdave wrote:WELL THAT SUCKS PHOTOBUCKET CHARGE NOW IF YOU WANT TO SHARE YOUR IMAGES :angryfire: :angryfire: :angryfire:
Plenty of free variants available
https://imageshack.us/
https://anonimag.es/
http://tinypic.com/
Will take some photos of the shell of my 220SEb when I get back. You might just as well take the whole car if it's in better nick than yours. Wouldn't ask for much more than what the wreckers would pay so might be affordable enough even when you include transport.
1965 220 Sb Sedan
OzBenzHead
Re: parts wanted
Post by OzBenzHead » Tue 04 Jul, 2017 10:32 pm
ekdave wrote:WELL THAT SUCKS PHOTOBUCKET CHARGE NOW IF YOU WANT TO SHARE YOUR IMAGES :angryfire: :angryfire: :angryfire: [...]
Dave: Did you manage to sort your Photobucket? Seems like odd behaviour.
I've just been to mine (a freebie) and have been allowed to post from it here.
OzBenzHead
Currently owned:
1965 W112 300 SE/C
1983 C126 380 SEC
and formerly:
1955 W180 220a
1965 W111 220 S
1970 W108 280 SE (my first Benz)
1973 W116 280 SE Crayford Estate (previously owned by Rolf Harris)
1980 W116 280 SE
1989 W124 300 E
1992 W201 180 E
1992 W201 190 E 2.0
+ numerous W108 and W116 rolling spares
and prior to my M-B enlightenment:
53 other cars of many nations, but mostly British oil-leakers (including 14 Rovers of the 50s and 60s) cursed by Lucas the Prince of Darkness. First car owned (at age 13): 1953 Fiat. Learned to drive in: 1927 Nash utility paddock-basher & Grey Fergie tractor. Driven distance (logged as at 30 June 2016): 4.6 million km.
ekdave
Re: parts wanted
Post by ekdave » Wed 05 Jul, 2017 5:50 pm
no unless i pay the ransome fee to photo bucks.. 100's of post i have do on several forums are gone :-(
it happened once before with imageshack .. and the task of re doing them all it not one im going to do ..
so unless i can find a cheap option .. no more posts with pics 4 now
ekdave
Re: parts wanted
Post by ekdave » Wed 05 Jul, 2017 6:01 pm
© 2004-2017 TinyPic®, a Photobucket Video & Photo Sharing Company
does this men Tinypic is owned by photobucket or just a generic name ??
Re: parts wanted
Post by CraigB » Wed 05 Jul, 2017 8:05 pm
just copied this from a post in another thread by AMG:
Join Flickr and then join the Flickr OZBENZ group -
Far easier. Just let us know you've signed up.
dynamike
Re: parts wanted
Post by dynamike » Wed 05 Jul, 2017 9:43 pm
1965 220 Sb Sedan
ekdave
Re: parts wanted
Post by ekdave » Thu 06 Jul, 2017 6:41 pm
whats going on i see my pic at back up ? maybe photo bucks have had a retthink ... since the backlash has been hugh
ekdave
Re: parts wanted
Post by ekdave » Wed 12 Jul, 2017 5:23 am
had a win scored 4 doors,, boot and left guard all in good condition for the finny .. just need a drives side and im in business
ekdave
Re: parts wanted
Post by ekdave » Wed 12 Jul, 2017 5:28 am
notice this soloniod under bonnet of w111 its disconnected and wondered what it was
? and ideas
https://www.dropbox.com/s/4bnkpm61lr1y8 ... d.jpg?dl=0
Re: parts wanted
Post by Bartman4800 » Wed 12 Jul, 2017 10:50 am
Never seen one of these, it is not on either of my cars.
It's got a crimped hose on it, so must have something to do with fluid pressure.
An external brake switch?
Could this be a remnant of a hydrak or something?
Ron? :laughing6:
merc-304
Re: parts wanted
Post by merc-304 » Wed 12 Jul, 2017 11:36 am
Bosch and numbers into Google ?
380 SEC
ekdave
Re: parts wanted
Post by ekdave » Wed 12 Jul, 2017 4:14 pm
no good in google .. seems theres a tv show called bosch . lol
merc-304
Re: parts wanted
Post by merc-304 » Wed 12 Jul, 2017 7:32 pm
Quick search for me came up with mercedes Pontoon type R 30 starter - 220 cold start valve ?
380 SEC
ekdave
Re: parts wanted
Post by ekdave » Wed 12 Jul, 2017 8:29 pm
merc-304 wrote:Quick search for me came up with mercedes Pontoon type R 30 starter - 220 cold start valve ?
ok there s 1 on evil bay 1500 usd .. lol so ill sell it for 1000 ...
now since its disconnected im assuming its not to vital ..
Re: parts wanted
Post by Bartman4800 » Thu 13 Jul, 2017 11:28 am
Did you check your VIN number?
Was your car originally fuel injected and engine has been replaced with a carburetored version?
ekdave
Re: parts wanted
Post by ekdave » Thu 13 Jul, 2017 6:27 pm
no ididnt but i do know the tranny was on the column but is now 4 on the floor ..
where do i do a vin search to find out what it was originally equipped with ?
a1110146000269
or 18094120029287 on inner guard
OzBenzHead
Re: parts wanted
Post by OzBenzHead » Thu 13 Jul, 2017 6:41 pm
dynamike wrote:You're not alone by the way
http://www.zdnet.com/article/photobucke ... om-demand/
Yesterday I, too, received the notice from Photobucket that I had been detected linking to third-party sites and that features of my account had consequently been restricted.
I had the account for 12 years, and it had received 27,932 views from others.
My reaction was to download the pix that mattered, then I deleted all 7,934 photos and 98 albums, and cancelled my account. When the "please explain" window popped up I gave them my reason: that they were practising "ransomware" and that they could go and autofornicate (or words to that effect).
Harrumph!
OzBenzHead
Currently owned:
1965 W112 300 SE/C
1983 C126 380 SEC
and formerly:
1955 W180 220a
1965 W111 220 S
1980 W116 280 SE
1989 W124 300 E
1992 W201 180 E
1992 W201 190 E 2.0
Re: parts wanted
Post by Bartman4800 » Thu 13 Jul, 2017 7:09 pm
ekdave wrote:no ididnt but i do know the tranny was on the column but is now 4 on the floor ..
a1110146000269
The first one is your VIN number. It tells me you have:
From the 1960s onwards the build up of the identification code is as follows:
The numbers have 14 digits on all models.
* The first three digits: type (as W number).
* Next three digits: body type.
* A. Seventh digit: 1 for Left hand Driven cars built in Germany, if built outside Germany this number would be a 5.
* B. Seventh digit: 2 for Right Hand Driven cars built in Germany, if built outside Germany this number would be a 6.
* Eight digit: 0 for standard transmission, 1 for Hydrak clutch or 2 for automatic transmission.
* Last six digits: serial number.
For example: 111.014-52-123456 would be the identification code for a 220SE (W111.014), Left Hand Drive built outside Germany (5), Automatic transmission (2) and with 123456 as a serial number.
The 2nd one is your engine number, which is for a 220S (carburettor)
Ergo:
Originally your car was a 220SE RHD manual, built in Oz or South Africa, but the engine was changed to a 220S
Read more here:
http://www.heckflosse.nl/iden4.htm
ekdave
Re: parts wanted
Post by ekdave » Fri 14 Jul, 2017 6:10 pm
thanks Bart
so i take the 220s motor if from an earlier merc 1956 - 1959
which makes the car even less desirable maybe the motor has a resale value as it has a 4 speed floor shift ..runs ok
Re: parts wanted
Post by Bartman4800 » Fri 14 Jul, 2017 6:25 pm
No Dave,
The engine is from a 220Sb. Sorry, I should have been clearer on that. It's not from a Ponton.
The engine is period correct, it's just not the original fuel injected engine.
Have a look here: http://www.heckflosse.nl/engine4.htm
If you look under your car, you might still have the original fuel tank with the electric pump hanging in front of it.
Yes the floor shift has a bit of extra resale value. People are looking for such a gearbox including the floor shift kit (me included)
Regards, Bart
ekdave
Re: parts wanted
Post by ekdave » Sat 15 Jul, 2017 6:47 am
ah i have it now
s or sb is the carby motor and the seb was injected
my old clunker is a seb but has had a down grade to carb version .. lol maybe a plus
merc-304
Re: parts wanted
Post by merc-304 » Sat 15 Jul, 2017 9:36 am
Will be a Plus....once you hang a Weber carby off it .
380 SEC
ekdave
Re: parts wanted
Post by ekdave » Sat 15 Jul, 2017 5:48 pm
merc-304 wrote:Will be a Plus....once you hang a Weber carby off it .
she has twin carbs atm .. think i have a manifold and carby in the parts i purchased last week ..
Re: parts wanted
Post by Mercmad » Sun 16 Jul, 2017 10:26 pm
Harrumph!
Me too, they can go and have intercourse with themselves, the greedy buggers.
Re: parts wanted
Post by Mercmad » Sun 16 Jul, 2017 10:32 pm
ekdave wrote:notice this soloniod under bonnet of w111 its disconnected and wondered what it was
? and ideas
Cold start valve for a very early Fuel injected finny.
ekdave
Re: parts wanted
Post by ekdave » Mon 17 Jul, 2017 5:42 pm
? and ideas
the Millkion dollar question is it worth anything i saw 1 on evil bay $1500 but cant believe anyone would pay that ?
Re: parts wanted
Post by Mercmad » Mon 17 Jul, 2017 6:51 pm
Definitely not because they were used on all of the mechanical fuel injected Mercedes and those of us who mess with these things often have few laying about .They are easily repaired ,which is nearly always a leaky valve inside them. They come apart so the seat and valve can be lapped . The coil is typical old style Bosch and the only time they fail is when they are hit by an engine ...lifting the engine out and the manifold wacks it . keep it as a keep sake or in case someone ever wants one. The ridiculous asking price might be because Gull wings use the same part ,but as i say,you would never need to buy one.
