250SE stalls when at Red lights.
oldbenz
Post by oldbenz » Tue 24 Mar, 2015 12:48 pm
Hello
I am new to these forums so apologies for any mistakes and misplacement of this topic.
I have a 1967 W111 250SE Coupe. The car runs like a dream but lately, when the motor has been running a while, it stalls when I am sitting at the lights or trying to park. Any clues anyone? :banghead:
Re: 250SE stalls when at Red lights.
Post by Bartman4800 » Tue 24 Mar, 2015 6:40 pm
Is it a manual or automatic?
Have you checked the valve clearance lately?
Have you checked the breaker points lately?
How worn are the spark plugs/leads/dizzy cap and rotor
Do you only do short runs; i.e. does the engine ever have the chance to get rid of gunk (these engines like to be revved)?
Does the engine get to a normal temperature (is the thermostat in good condition)?
etc etc...
finnie_am_I
Post by finnie_am_I » Tue 24 Mar, 2015 7:19 pm
Hi There
Have you checked your fuel tank? If the tank is dirty they will run for a while then as the strainer in the tank starts to block with all of the dirt it will starve the motor and it will stall. Usually it will restart after a minute or so as the negative pressure form the pump side is no longer present.
The other thing to check is for a leaky brake booster. Does the idle drop drastically if you press the brake pedal to the floor? We had a booster that was sucking air as the diaphragm was shot after being contaminated with brake fluid. This sounds more like your problem considering it is during red lights and parking situations.
We had the booster issue with a 220s with the fire wall mounted ATE booster which was fixed by replacing it with a like unit.
We had the dirty tank issue with a 1962 220SE where it would start and run fine and then just loose power or just stop. We had to clean the tank which was so dirty, now not a problem in the world will do 60mph all day every day.
Good luck!
oldbenz
Post by oldbenz » Sun 05 Apr, 2015 9:30 am
Hi. Thank you for the replies.
Bartman4800: My coupe is an auto. I have electronic ignition. It could be valve clearances. I do take it for pretty good runs and cleaned out the tank a while ago. Engine does get to normal temperature.
finnie_am_I: It could very well be the brake booster. It feels like a vacuum issue, if they are related. I recently replaced the master cylinder but gee, I thought I was really careful on making sure I did this well. I will certainly investigate this possibility.
oldbenz
Post by oldbenz » Sun 05 Apr, 2015 9:39 am
finie_am_I: I just thought of something in addition to my previous reply. I noticed my brakes, whilst feeling quite full, require more effort to brake than usual. Sometime, when parking, I hear a slight hissing noise. Am I saying the obvious? :color:
Post by Bartman4800 » Mon 06 Apr, 2015 11:57 pm
Great when people answer their own questions :dance: :laughing6:
finnie_am_I
Post by finnie_am_I » Fri 10 Apr, 2015 7:38 pm
Hi Bartman4800
Glad it was of some help. Usually works out a lot cheaper when you answer your own question as well!!
Best of luck
