Rear Brake Cylinders
Post by Bartman4800 » Tue 03 Mar, 2015 8:21 pm
While taking parts from my 60 finnie (drum brakes all around and booster)
And putting them on my 63 finnie (front disk brakes and booster)
I noticed that the older finnie has 1" rear brake cylinders, while the later one has 3/4" rear brake cylinders.
Both have a booster, and I noticed that the Disk brake car has a tendency to lock up its front wheel quite easily.
Would it be a good idea to mount the larger rear brake cylinders on the 63 car?
Regards, Bart
Jeremy
Re: Rear Brake Cylinders
Post by Jeremy » Tue 03 Mar, 2015 9:27 pm
I think if the front disks are locking up easily that might indicate a problem with them (or your right foot :blackeye: ) rather than a deficiency in the rear drums. If you changed those to larger units it might not work so well with the standard master cylinder and brake bias settings :dontknow:.
1965 220Sb
Post by CraigB » Tue 03 Mar, 2015 11:10 pm
I agree re locking of wheel, that sounds like a problem, and just one wheel locking? New brake hoses so internals of both of them good and same flow to the front? Not drums, but as an indication of role of rear brakes, the rear calipers and pads on a big 560sel is the same as a W108 from the 60s, but the fronts got substantially larger.
Post by John Green » Wed 04 Mar, 2015 10:00 am
There are multiple versions of the brakes on these Finnies. The trick is to get everything to match. There is a ratio that I could look up that determines what size wheel cylinder you need for a certain size master cylinder and then you need to take the booster into account. And then there are systems (I think on the 230S) where there was a limiting valve between the master cylinder and the rear drums.
If it feels odd when trying to stop and you are sure that all of the various components are operating correctly the usual cause is that someone has swapped in some parts that do not match the rest of the car.
Post by Bartman4800 » Wed 04 Mar, 2015 10:49 am
Thanks guys.
The locking up was at a test drive before I tackled the front calipers issue. And also with very old and rock hard tyres. Locking up was under hard braking only.
John, you are probably spot on with the volumes of the combined brakes. The master cylinder is the same on both, but I think the front calipers have a larger displacement than the front drum cylinders.
That might be why the rears are smaller.
It was worth a question and I think I got the answer. Leave as is and make sure all components are good :dance:
Craig: for your peace of mind: I replaced all the brake hoses this weekend.
I think the rear ones were still original.
I also replaced the oil sender hose. Now this one was cracked! :think:
Post by Bartman4800 » Thu 05 Mar, 2015 4:16 pm
Oh, and both sets (the 3/4" ones on Kermit as I found out) and the 1" ones from the donor (4 years ago done by Power Brakes) have been resleeved with Stainless Steel.
So if anyone is looking for a set of refurbished very early rear brake cylinders (1" diameter), I have a reconditioned set for sale.
