gear stick wont go past neutral into park
hellohello123
Model you own: w209
Post by hellohello123 » Sun 16 Apr, 2017 11:28 pm
Just wondering if some technical people could advise
its only happened twice, but when im about to parkt the car, I am unable to go past neutral into park
its almost like its electronically locked,
I presses, depress brake, and handbreak but it doesnt help,
if I keep on trying it just seems to work,
its only happened twice, but im just worried its the start of a big problem
thanks in advnace
Pete49
Re: gear stick wont go past neutral into park
Post by Pete49 » Mon 17 Apr, 2017 1:13 pm
Don't know about this problem in mercs but had similar problem with another brand. I would check the linkages first as there may be a bit of slop or a twisted one.
1978 W123 300D Maple Yellow
1983 W123 280TE Champagne
1975 W116 450SEL Silver blue
dan108
Post by dan108 » Sat 18 Nov, 2017 7:25 am
Try new brake switch near brake pedal
Let us know how you go cheers
Post by Ivanerrol » Sat 18 Nov, 2017 11:21 am
There is an ECU board under the gearstick.
Everything is controlled electronically
The Brake Switch is the first place to start.
Never get any liquids anywhere near the gearstick on a 722.6. Coffee of ChokaCola has been known to kill the circuit board underneath the stick.
A friend of mine just had that circuit board replaced two weeks ago - $600.00 for a second hand unit.
:pray: Its not the board that's playing up
dan108
Post by dan108 » Sun 26 Nov, 2017 5:45 am
Hi did you end up resolving your shifter problem
I ask as mine after going for a long drive i have the same problem wont go past neutral so have to wait for about Five minutes and then i can get reverse
Cheers Dan
