Changing gears without key
celine240
Model you own: w209
Post by celine240 » Sat 14 Nov, 2015 11:47 am
Hi, I have a 2004 clk 240 and was wondering is anyone knew if it was possible to change the gears without having to have the key/battery hooked up?
celine240
Model you own: w209
Re: Changing gears without key
Post by celine240 » Sat 14 Nov, 2015 3:38 pm
I know this is possible on some c classes, but just wondering if it is on my clk too. :)
Post by Tony From West Oz » Sat 14 Nov, 2015 6:44 pm
With my '98 and my wife's '99 C class it is not possible to remove key unless the transmission is in "P".
We cannot move the selector from "P" unless the key is in the ignition and the foot is on the brake.
A good safety feature.
The car has been designed to stop idiots selecting gear when the brake is not applied.
I hope this helps,
Post by pastelgrey300D » Sun 15 Nov, 2015 2:58 pm
Is there a slot or button near the trans selector you can push in to release the shifter? I know a lot of jap cars that have this lockout feature have a way to override it.
Some cars have a pushbutton, some have a plug that you can remove and then insert a screwdriver to release and some have a slot where you can just put the ignition key in:
Also just found these images online, might be a similar arrengement for your car? This looks like it is out of the owners handbook so there might be something in there as well?
celine240
Model you own: w209
Post by celine240 » Sun 15 Nov, 2015 6:46 pm
Thanks for the images / info :)
Will have a look and update on any success!
celine240
Model you own: w209
Post by celine240 » Tue 12 Jan, 2016 12:48 am
There was success!
