Oil and Other fluids
Raijin
Post by Raijin » Thu 22 Jun, 2017 12:48 pm
Hi Guys
Just wondering what Oil you use in your 114's I have a twin card 250.
I called MB local spares here and they said they used to sell a Classic Oil but no longer.
Caltex site said talk to deal and Castrol gave me 3 different types.
I assume the other fluids like break fluid would just be standard stuff.
Re: Oil and Other fluids
Post by Bartman4800 » Thu 22 Jun, 2017 3:13 pm
Do a search on oil on this site.
This has been discussed a zillion times.
For BRAKE fluid, use dot 3 in your classic. But most of all, inspect your BRAKE hoses for cracks - replace if you see any.
Raijin
Post by Raijin » Fri 14 Jul, 2017 11:24 am
I ended up getting some Penrite 20w 60
Post by Bartman4800 » Fri 14 Jul, 2017 12:39 pm
Why?
I am pretty sure your manual says 15w40
If you use synthetic you might actually find it can start to leak from the rear rope seal
Also, only use thicker oil (the 60 designation) when you have low oil pressure with a warm engine
Thicker oil is not better for an engine, it takes longer to get to the important places!
Like I said, have a search on this site.
Return to “W114 and W115”
