W115 Ride Height
Driver
W115 Ride Height
Post by Driver » Thu 15 Jun, 2017 8:49 am
We are rebuilding the suspension on the W115 230.4 and need the ride height for the front and rear so that we can order new springs.
Re: W115 Ride Height
Post by Giles » Thu 15 Jun, 2017 10:26 am
This may help. It you require parts numbers for the springs let me know.
Post by AMG » Thu 15 Jun, 2017 11:52 am
Driver wrote:We are rebuilding the suspension on the W115 230.4 and need the ride height for the front and rear so that we can order new springs.
Are you aware of the "points" system that MB uses on their spring part numbers, which correlates to the options fitted to your vehicle?
This is what dictates the spring part number and the shim part number used to return the correct ride height.
Driver
Post by Driver » Sun 18 Jun, 2017 3:38 pm
Thanks Giles. Every little bit of information helps.
Return to “W114 and W115”
