Hello from the new guy!
EllEsssGuy
Post by EllEsssGuy » Fri 04 Nov, 2016 9:38 am
Hey everybody!
I just picked up my new project car: A 1976 280 US market car in tan with bamboo interior. I have some fun plans for this car, ending with it being used as a "business trip" car, to replace my Buick Park Avenue. I do between 60-80000 miles per year (depending on how well business is going), and I want a comfortable, interesting car to spend all my time in. Enter the 280. I will be swapping in a mild (400ish HP) 5.3 liter vortec truck motor and 4l60e trans, keeping the stock steering and rear end (maybe a LSD swap?). I will be upgrading the brakes with a 560 sel front disc/caliper swap and MC, and E320 rear disc/calipers. I will be replacing the carpet and seat pads along with a nice stereo setup, MAYBE swap out the A/C parts with a GM setup if I can make it fit correctly, but the rest of the car should be pretty stock.
I have a question to ask though. I have found a picture of a nice, brown Norwegian 250 sedan with black steel wheels that appear to be 16 x 8s. Round holes around the edges, so I am assuming they are stock wheels. I will try to post the pic if I can figure out how (as well as pics of my car as it sits), but here are a couple of pintrist links:
https://www.pinterest.com/pin/506232814337395049/
https://www.pinterest.com/pin/318348267384034282/
I know its a long shot, but does anyone know what these are off of? I love the look and the fact that it isnt slammed ( maybe 2 lowered inches?). I am going to need to do larger wheels anyway.
Thanks in advance,
EllEsssGuy
Re: Hello from the new guy!
Post by EllEsssGuy » Mon 07 Nov, 2016 5:05 am
OK, looks like these are 1990 300SL steel wheels. 16x8 25et. Shouldn't be too hard to find a set locally.
Post by CraigB » Mon 07 Nov, 2016 9:29 am
Welcome. Would never have thought of steelies on a 300sl, but great to be able to get the size - if only you could find chrome hubcups and trims to fit! My main point of caution would be the ratio of the diff. Its probably something like a 3.6 and will have that big engine screaming to keep up with highway speeds. You might want to look around at what ratios available and what fits what. I don't know your model well but W116 or gen 1 W126 might fit. 500 SEL/SEC are often 2.24 and better suited i would think. Not sure what 450 W116 is but would be better no doubt and 6.9 diff is 2.65 I think but no doubt harder to find.
And more people might see your post if you put this in the 'modded' forum.
EllEsssGuy
Post by EllEsssGuy » Mon 07 Nov, 2016 12:31 pm
Hi Craig,
I had thought about that. Probably going to try to source a pre '84 500 sec rear. LSD and a 2.46 ratio. Seems it will bolt in if I change the flange. Going to try the existing rear for a little while though, should be some fun acceleration with the 3.92s. My planned highway usage will probably have me swapping that out pretty quickly, even with the .63 overdrive.
Sam
EllEsssGuy
Post by EllEsssGuy » Mon 07 Nov, 2016 12:33 pm
And thanks for the suggestion on the "modded" area, I will.
Return to “W114 and W115”
