Troubleshooting Ingition Module/Coil
nvrau
Model you own: w168
Post by nvrau » Tue 26 Aug, 2014 7:22 am
My W168 is missing on cylinder #2. I'm looking for information on how to troubleshoot the ignition module/coil before I purchase a new one.
I recently replaced the starter using the top replacement technique. After reassembly, cylinder #4 was missing as per ECU code P0304 (I believe). I reattached the module connector to ensure a good connection, cleared the code and then it switched to missing on cylinder #2 with ECU code P0302. I again ensured there was a good connection to the module a couple of more times and each time I start the car is comes up as missing on #2 (P0302).
I replaced all four spark plugs but still code P0302 is coming up.
Can anyone assist with troubleshooting procedure or point me to a resource online with information?
nvrau
Model you own: w168
Re: Troubleshooting Ingition Module/Coil
Post by nvrau » Tue 02 Sep, 2014 12:59 pm
Well, I was able to narrow the issue down to cylinder #2 injector not being triggered by ECU. It is getting the constant 12v+ needed but not the pulsing 12v- like the other injectors are getting.
While the car is running, if I unplug & then plug-in the injector connector onto the injector, the car does run slightly better. This tells me the ECU is seeing the injector is connected.
Unless someone chimes in with a suggestion on what to try next, I guess it will be off to a mechanic for further inspection...
nvrau
Model you own: w168
Post by nvrau » Wed 24 Sep, 2014 9:15 pm
Well, I got it running... and it was in-fact the GRY/BLU wire going from injector 2 to the ECU.
Details of the process can be read on BenzWorld.org.
If you need assistance with your ECU in Australia, give Australian ECU Repair a go. Justin was very helpful!
