Fresh/Recycled Air Button
nvrau
Model you own: w168
Post by nvrau » Mon 05 May, 2014 6:30 am
I have a pet-hate with the car always resetting the fresh/recycle air to fresh after a period of time. Has anyone attempted to change this behaviour or know of a way to disable it?
I don't care what the reasoning behind it is. I don't want fresh cold air coming in when I am trying to warm the car, as well, I don't want fresh warm air coming in when I am trying to cool the car.
Cheers!
Hendrik
Re: Fresh/Recycled Air Button
Post by Hendrik » Mon 05 May, 2014 11:43 am
Assuming the system is similar to the earlier climate control systems, you may well find that the system is smarter than you think, it does in fact block off fresh air partially when it thinks that is the requirement.
Post by Greg in Oz » Mon 05 May, 2014 12:14 pm
The HVAC system switches from recirculated air to fresh air after a period of time for very good reason. It is to prevent the passengers (and driver in particular) from becoming drowsy through breathing stale air with a high level of CO2. I can understand that you may not want to have to heat or cool fresh air, however the heater and A/C are more than capable of doing this and I believe the extra energy used doing so (compared to heating or cooling recirculated air) will be minimal in comparison to the energy used propelling the vehicle. I also believe most heat loss and gain in a motor vehicle will be through the metal panels and glass rather than through non-recirculated airflow. The recirculate setting is really only intended for use when the air outside is very dusty or smelly and the assumption is that the conditions won't remain that way for more than a short period of time. Personally, I hate travelling in a vehicle with the air set to recirculate or the outside air shut off.
