ML270CDI Diesel pump is leaking
Neo
Model you own: w163
Post by Neo » Fri 28 Apr, 2017 2:38 pm
Hi all,
My Diesel pump is leaking on the right side (Air filter side). When put my head down in the engine bay I can see the drips (1 every 3 seconds) falling behind the pump. I have checked the fuel lines but my guess is it's coming from the lower left cover plate which is part of the pump. I guess I'm lucky it's on the low pressure side but if I remove the pump is it possible for me (or someone) to remove that cover plate and reseal it?
Thanks for your help.
Neo
Re: ML270CDI Diesel pump is leaking
Post by Bartman4800 » Tue 02 May, 2017 4:25 pm
Not trying to be pedantic but a few words of warning:
Common rail diesels run at a very high fuel pressure (up to 2000 bar/29,000 psi)
If you get fuel injected in your finger or other body protrusion make sure the ambulance is present.
Fluid injection under the skin is fatal if not addressed immediately!
If you can get medical help you might get away with some nasty scars running up your arm where the surgeon had to cut the skin to flush the fuel out.
To be honest, I think this is a job for the BOSCH diesel specialist
Neo
Model you own: w163
Post by Neo » Tue 02 May, 2017 4:39 pm
Thanks Bart,
I'm going to be removing the pump to fit a seal kit but I was already concerned about the high pressure and was wondering how long it takes to die down. Your point is very valid so I'll double up on the nitrle groves and make sure that only a long spanner is touching that HP rail when I losen that pump nut. Will also wear googles too.
Thanks again for the "heads up" on this ;-)
Roger82
Post by Roger82 » Wed 27 Dec, 2017 10:11 am
I've serviced my own ML270 high pressure pump, they are pretty simple.
But as a safety note to add to the others, These high pressures can cause the diesel to cut through steel so gloves and goggles will not protect you much.
I do wonder what pressure it's running at idle...
2002 ML270 Classic wife's car
1983 500SEC fixer-upper
